Curious
Old Oct 18, 2025 | 12:01 AM
Darkbluecoupe's Avatar
Darkbluecoupe
Default Curious
I finally got the buiilt differential with 3.73 gears installed last week.Car feels a ton faster.Im dying to get out to the track and see some numbers.Installed an A&A kit with small pulley,PRC full cnc heads,228R cam, headers,LS6 intake Yank 3600 converter on freahly beefed up transmission.I have the Mickey Thompson sticky radials on it.With street tires 2.73 and no supercharger it went 11.40’s with a 2.11 60 ft so I hope to see some good numbers with some traction.
Old Oct 26, 2025 | 11:29 AM
Rkreigh's Avatar
Rkreigh
might dip 10s see the reduction in 60 ft times
1 tenth = 2 tenths quicker in quarter (approximately)
good gear
you will like it
Old Oct 27, 2025 | 10:19 PM
RonSSNova's Avatar
RonSSNova
Might? I’d think low 10’s if it hooks.
I run the same SS3600, but 3.42 and run 10.70’s in good air with a decently prepped track. NA cathedral port 6.2.
Same tires.
I run 16-18 lbs in the slicks.
Also set the trans up so it won’t up shift to 2nd if it spins and I lift.
When will you run it?
To Curious
