1997 Procharger Fit
Old Dec 16, 2025 | 04:04 PM
jnknotts's Avatar
jnknotts
Cruising
Default 1997 Procharger Fit
I have a 1997 Corvette with a pro charger with A&A bracket but it rubs on my hood liner, is this normal, any way to fix it or is this just my life?
Old Dec 17, 2025 | 08:31 AM
abc63's Avatar
abc63
Mine also does touch the hood liner. IIRC it's the inlet tube.
Old Dec 17, 2025 | 08:38 AM
jnknotts's Avatar
jnknotts
Cruising
Old Dec 17, 2025 | 07:16 PM
helga203's Avatar
helga203
Originally Posted by jnknotts
Never seen that before. Are they stock height motor mounts. If not you can install short motor mounts.
I even had their original bracket when they first started making them and didn't touch the hood. Same P-1 SC as yours
Old Dec 18, 2025 | 08:35 AM
jnknotts's Avatar
jnknotts
Cruising
My mounts are stock, do you have a source for short mounts?
Old Dec 18, 2025 | 08:06 PM
Smoken1's Avatar
Smoken1
Hinson has 3/8's inch shorter mounts. I would also get the heat wraps for them.
https://hinsonmotorsports.com/produc...44351184503005
To 1997 Procharger Fit
