HELP - Firewall openings?
Old Feb 20, 2003 | 08:08 AM
jpas's Avatar
jpas
Default HELP - Firewall openings?
Where is the best place in the firewall to run wires / tubes?? I have my engine out now and this would be a great time to run the boost controller and gage lines/wires.
Old Feb 20, 2003 | 09:36 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: HELP - Firewall openings? (jpas)
Under the drivers side upper left you will see the hood release cable going through. I would go through there. From the engine side its right under the power steering booster. :seeya
Old Feb 20, 2003 | 01:47 PM
intel55's Avatar
intel55
for the boost gauge I run next to the hood release. On the pass side I would either drill a lil hole next to the IPC harness or peel back part the uhege grommet and push some through there. I opted to drill next to the IPC and it comes out right under the batt. On the drivers side also I ran a some lines up the door pillar and under the hood and then under the firewall. No cutting thee and it actually all fit with being able to be noticed. :cheers:
Old Feb 20, 2003 | 05:01 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: HELP - Firewall openings? (intel55)
large grommet behind the battery.
To HELP - Firewall openings?
