N2O bogging? Need Advice!
Old Feb 23, 2003 | 10:09 PM
twincam47's Avatar
twincam47
Default N2O bogging? Need Advice!
Got a wet set up......Hit N20...Car boggs........
Stock 03 Z06.......Pea sizes......52 fuel / 33 N2O.......
What do we need to Do?
Old Feb 23, 2003 | 10:29 PM
SilverStateZ06's Avatar
SilverStateZ06
Default Re: N2O bogging? Need Advice! (twincam47)
What rpm do you activate at?
Do you purge first?
[Modified by SilverStateZ06, 7:30 PM 2/23/2003]
Old Feb 23, 2003 | 10:37 PM
twincam47's Avatar
twincam47
Default Re: N2O bogging? Need Advice! (SilverStateZ06)
4000 rpm
no purge kit
Old Feb 23, 2003 | 10:54 PM
SilverStateZ06
Try activating at 3K (relatively safe on the bottom end - especially with a small shot).
Also, make sure to purge first. Without a puge kit, before you get to the track, with your bottle on, go full throttle and activate your unit until you feel it hit. You are now purged and ready to race.
The reason purging helps, is that when you turn the bottle on, air is in the nitrous side of the line in front of the nitrous. When you activate the unit, you get additional fuel from the fuel side of your unit, but instead of getting the nitrous to make the mixture perfect, you just get ordinary air for a moment or two - hence the bogg. When you purge, you will have nitrous pushing right up against your nitrous solenoid. Upon activation, the nitrous and fuel get released at the same time and in the proper ratio - result - no bogg.
Hope that helps.
Old Feb 23, 2003 | 11:26 PM
ICULUKN-C5's Avatar
ICULUKN-C5
check the following things..
1. is the bottle open
2. is there power to the n20 solenoid.
bogging will happen when you spray only fuel into the manifold.
Old Feb 23, 2003 | 11:51 PM
twincam47's Avatar
twincam47
Default Re: N2O bogging? Need Advice! (ICULUKN-C5)
bottle opener is activating..........
hit the switch about 4 seperate times....Figured that would have purged the system.
Will double check N2O solenoid operation...Anything else come to mind?
Are the pea sizes OK....This was a used system for a 100 shot.
Old Feb 24, 2003 | 12:43 AM
SilverStateZ06
Turning on the bottle does not purge your system.
You have to get rid of the air that is in the line by activating the unit (unless you have a purge kit).
Oh, and your jetting is wrong. Here are some rough guidelines (ever setup is a little different). These numbers were found on LS1.com in the nitrous section - I don't know if they are accurate, but several posts confirmed these numbers - some setups were slightly leaner, but these are the safer numbers.
For a 50 shot:
35 nitrous and 20 fuel
For a 75 shot:
41 nitrous and 24 fuel
For a 100 shot:
52 nitrous and 33 fuel
[Modified by SilverStateZ06, 9:51 PM 2/23/2003]
Old Feb 24, 2003 | 03:32 AM
twincam47's Avatar
twincam47
Hitting the switch=sprayed 4 seperate times.....should have purged the lines.
Silverstate......If you are sure that the pea sizes are correct...Then that would account for the BOG.....The fuel and N2O lines are backwards from the solenoids to the spray nozzle......Can we verify this?
Old Feb 24, 2003 | 09:05 AM
ICULUKN-C5's Avatar
ICULUKN-C5
nitrous is always the bigger of the two jets numbers. Sorry that I didnt catch that on your last post.
Old Feb 24, 2003 | 10:47 AM
twincam47's Avatar
twincam47
Thanks guys, checking to see if the lines are reversed...will advise.
:flag
Old Feb 24, 2003 | 01:52 PM
Allgonoshow's Avatar
Allgonoshow
VERY IMPORTANT!, did u change out the stock plugs? They are platnum(dont know how to spell it) and are about 2 steps too hot. Get some NGK TR6's gapped at bout .38 - .40(100hp shot). They seem to be the fav for N20 on this forum.
If u do have new plugs already and they are gapped good check the jet sizes to make shure they are not swapped like said earlier.
Old Feb 24, 2003 | 01:56 PM
1QWIKLT1's Avatar
1QWIKLT1
Default Re: N2O bogging? Need Advice! (Allgonoshow)
Your jets are backwards.......
Old Feb 25, 2003 | 07:50 PM
big bollas's Avatar
big bollas
Default Re: N2O bogging? Need Advice! (1QWIKLT1)
jet are backwards!! and you should use ngk tr6 plugs gapped at 38 if you havent alredy done so. :iagree:
Old Feb 25, 2003 | 11:57 PM
twincam47's Avatar
twincam47
Default Re: N2O bogging? Need Advice! (big bollas)
we had already done the plugs....we have now swapped the pills and are waiting for better weather.........Lots of misty rain, cold and possible icing conditions...
will let yall know in a day or two....................
Thanks in advance for all the help and responses... :flag
Old Feb 26, 2003 | 01:03 PM
z0sense's Avatar
z0sense
A 52 n2o and a 33 fuel would amount to about a 100 shot.
n2o (the brand) states that a 47 and 25 are a 100 shot.
However because you are pilled extremely rich (safe) it would probably amount to 100 instead of 115-120. (a 55 n2o pill is a 125)
Also you will have to have substantial pressure on the n2o side. Do you have a bottle heater? I run mine at about 1100 psi, but 900-1050 is what is recommended!
Pressure is importrant because if you run low pressure you will run into an overly rich condiditon, and vice versa for high pressure, overly lean.
Not running the right pressure (too low) will also cause you to bog tremendously.
Old Feb 26, 2003 | 02:12 PM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
Called NX a few days ago and here are the latest jet ratings:
100 shot: 52 Nitrous / 31 fuel
125 shot: 57 nitrous / 33 fuel
150 shot: 62 nitrous / 35 fuel
Old Mar 1, 2003 | 12:39 AM
twincam47's Avatar
twincam47
Default Re: N2O bogging? Need Advice! (OliverM5)
Okay Guys...............reversing the pills did the trick.......
this thing hits like a hammer now......Haven't stopped grinning for an hour.
Thanks for everyones help. :thumbs:
To N2O bogging? Need Advice!
Old Mar 2, 2003 | 08:09 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Someone is having fun now.......... :auto:
Old Mar 2, 2003 | 11:49 PM
z0sense's Avatar
z0sense
n2o is a drug.....now yo u are addicted....when it all came down to it I decided that having a charger was cheaper. 300 bottles at 30 bucks per bottle = 9000.00....and I have all the receipts.
:cheers:
Old Mar 3, 2003 | 12:06 AM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: N2O bogging? Need Advice! (z0sense)
300 bottles!! :eek: I think I have only counted 6 bottles in over a year with 2 different engines! :lol:
