Trouble Code: P0441 ????
Old Mar 18, 2003 | 10:16 PM
Lambchop's Avatar
Lambchop
Default Trouble Code: P0441 ????
I've had this trouble code pop up twice now and I'm wondering if this is a serious problem or is there something I can do to avoid having my check engine light come on every other day.
P0441 = EVAP System No Flow During Purge
Can anyone help? :confused:
Old Mar 19, 2003 | 12:58 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: Trouble Code: P0441 ???? (Lambchop)
Have you double checked to make sure that all of the purge solenoid connections are still tight after your Magnuson install (where the hose goes into the supercharger case and both sides of the solenoid as well as at the back of the right valve cover), I know when I connected the purge solenoid, both ends of the hose were stretched pretty tight and would pull loose with just a little touch so I stretched (took the kinks out) and secured them with zip ties to make sure they don't move. :cheers:
Old Mar 19, 2003 | 06:46 PM
Lambchop's Avatar
Lambchop
Default Re: Trouble Code: P0441 ???? (runamuk)
Just checked everything and it's all tight. I'm not sure what it is, but it's only popped up during my 25-minute drive with the cruise-control set at 70 mph.
:confused:
Old Mar 19, 2003 | 07:26 PM
Dave00C5's Avatar
Dave00C5
Not a good thing Lambchop. I'd give Tim a call at LPE. :yesnod:
Old Mar 27, 2003 | 09:28 PM
Lambchop's Avatar
Lambchop
Default Re: Trouble Code: P0441 ???? (Dave00C5)
Haven't been able to call Tim, although, I've emailed him a week or so ago and haven't heard back. :confused:
Ed, you've got any ideas? It gave me the code again on the way home from work today.
I don't think it's a major problem, just annoying. :banghead:
Anybody???? :sleep:
To Trouble Code: P0441 ????
