Edumacate Me
Old Mar 19, 2003 | 12:17 PM
Belloc's Avatar
Belloc
Cruise-In VII Veteran
St. Jude Donor '06
Default Edumacate Me
http://cgi.ebay.com/ebaymotors/ws/eB...category=33741
Will this fit the Vette LS1? What kind of bump would this give me over stock? How hard would it be to install?
Old Mar 19, 2003 | 01:10 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Edumacate Me (Belloc)
This wont fit the C5.
vetterdstr :cheers:
Old Mar 19, 2003 | 03:41 PM
C6VETTE4FUN's Avatar
C6VETTE4FUN
that is correct...it will not fit. Reason...mostly only brackets which is the main
reason the unit application for the c5 is over 6k :crazy:
Old Mar 19, 2003 | 03:58 PM
Belloc's Avatar
Belloc
St. Jude Donor '06
Default Re: Edumacate Me (1997C5VTBOY)
I'm pretty decent at metal work could I fab my own brackets?
Old Mar 19, 2003 | 04:09 PM
Nitro-C5's Avatar
Nitro-C5
Moderator
St. Jude 15 Year Donor
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '08-'25
I would think given the recent problem history of SC made for the C5, you would even have more issue for a system that is not designed for the C5. :yesnod:
Old Mar 19, 2003 | 05:10 PM
boblackhardtop's Avatar
boblackhardtop
If you want a centrifugal SC look for a used ATI, decent price & complete bolt on kit.
Powerdyne are nonintercooled & will only give you 20-30% increase in HP.
Old Mar 19, 2003 | 07:08 PM
C6VETTE4FUN
Default Re: Edumacate Me (Nitro-C5)
You could make you own brackets but, these are must be precession cut
and measured brackets. If you read thru the C5 forced induction, you will find that some if the issues is belt slippage..etc All the bugs are not out of
most of the units from what i read.
I have two good friends who did modify brackets but they were for much
simplier applications! One was a 1968 olds 442 and one was a 1980 pontaic Trans-Am. I assisted on the install. Yes, it can be done but with much time
to loose. You would rather be driving the working.
If you would like to get a used unit, I would check ebay every so often. Last
week a used C5 Carol unit (complete) was sold for $4k. (great deal)
Item # 2403618806
The worst thing that could happen is the main bearing is shot which can
be overhalled for a small ammount of $ from the factory.
good luck..
:D
[Modified by 1997C5VTBOY, 3:35 PM 3/20/2003]
To Edumacate Me
