TT from TTI
Apr 10, 2003 | 04:31 PM
TT from TTI
Does anybody has the Twin Turbo from Turbo Technology?
Apr 10, 2003 | 04:44 PM
St. Jude Contributor
Re: TT from TTI (angel95135)
allmost :jester
Apr 10, 2003 | 05:56 PM
Yes, we install them.
Nate has one on his ride. King_Pin is next, and I have about 6-7 others lined up through June:crazy:
Give us a call:)
[Modified by billreid1@***.net, 3:57 PM 4/10/2003]
Apr 10, 2003 | 08:38 PM
I go in a week from Monday, first install in Michigan. I will be posting progress as things happen.
Apr 10, 2003 | 10:29 PM
Re: TT from TTI (VETZILLA)
Right on :)
Apr 12, 2003 | 11:36 AM
Re: TT from TTI (billreid1@***.net)
Talked to Nate yesterday. My car arrives on Friday the 25th of this month. I hope to pick it up on 8th or 9th of May. :thumbs:
Apr 12, 2003 | 12:44 PM
Re: TT from TTI (Shinobi'sZ)
Should be interesting to see the results!
I almost pulled the trigger on a TTi setup, however, I am going to wait and see what the results are from some of you guys. Besides, I *really* want to see and ride in a Vette that has a TTi - before I buy. Now all I have to do is make some time to get over to AZ and see Nate's ride!
:thumbs:
Apr 12, 2003 | 01:31 PM
Can somebody provide a link with the details on this kit? :confused:
Apr 12, 2003 | 06:08 PM
Re: TT from TTI (Mr. Pepsi)
http://www.turbotechnologyinc.com/C5.HTML
I don't know the pricing information. I'm hoping MTI will add this to their arsonal!
Lates,
Justin
[Modified by ambitin, 5:08 PM 4/12/2003]
Apr 12, 2003 | 07:58 PM
It's the same kit Cerra uses. :thumbs:
Apr 12, 2003 | 09:09 PM
I've decided to go with the TTI setup as well. :D
Apr 13, 2003 | 02:34 AM
Re: TT from TTI (ganson)
Looking at running max boost on my Lower Compression Forged LS6 w/Stage II Blower Heads and 224 Cam...should be interesting at 12+lbs of boost.
[Modified by Shinobi'sZ, 11:35 PM 4/12/2003]
Apr 14, 2003 | 02:25 PM
Cruise-In I Veteran
St. Jude Contributor '04
Apr 14, 2003 | 08:44 PM
Re: TT from TTI (Nate@xtreme)
Just curious: Can the boost level of the TTI kit be easily increased over the stock 7 PSI if a person wanted to?
Apr 14, 2003 | 08:51 PM
You can raise the boost but I think 7-8 pounds of boost is all the stock bottom end can handle. Mine goes on in late may early june. I reccomend going on a ride in Nate's.
Apr 14, 2003 | 09:15 PM
Re: TT from TTI (ZOsixTT)
Nate, you mentioned the C5 version dynoed was set at 8 psi.
Is this still safe boost to a stock LS1 engine?
(I taught 6-7 psi is the max.safe range.)
Apr 14, 2003 | 09:45 PM
The stock LS1 can handle slightly more boost... but the stock LS6 is limited to 6-7 pounds due to its higher compression ratio. :)
[Modified by billreid1@***.net, 7:48 PM 4/14/2003]
Apr 15, 2003 | 08:27 AM
What are the HP & TQ numbers on a stock LS1 with the TTI setup?
Apr 15, 2003 | 08:46 AM
Here's TTi's numbers as of 2/14... not sure if they consider this graph as final numbers... but its real close to what our crate LS6 motor put out at 7 psi in that RPM range :)
[Modified by billreid1@***.net, 6:54 AM 4/15/2003]
Apr 15, 2003 | 10:10 AM
Can the boost be adjusted?
