Forced induction recommendations needed:
Old Apr 22, 2003 | 08:56 PM
ericdwong's Avatar
ericdwong
Default Forced induction recommendations needed:
After getting blown away by a Toyota Supra TT in my boner stock MN6 LS1 98 coupe I'm feelin the need for more power. Anyway, my car is my daily driver so I need it to be reliable. I know of the 3 S/C kits. Vortech I'm most familiar with as my previous car had one available that I looked into but never bought. ATI claims to be very reliable. And the Magnuson I probbly wouldnt consider cause of the hood. I'm not sure what the turbo options are either.
Whats the most upgradeable for later down the road should I decide to build a motor?
Anyway presently I'm not really interested in doing a cam job, so I'd want it to be bolt on to a stock LS1 as easy as possible. I dont like lumpy idles.
I would probbly run an J&S Electronic Safeguard unit.
Old Apr 22, 2003 | 09:42 PM
Bill Reid's Avatar
Bill Reid
Default Re: Forced induction recommendations needed: (eRiCdWoNg)
Don't feel bad... there are some pretty sick Supra's running around...
We tend to lean towards the ATI kit but Vortech is also a great kit worth considering. Both kits can have pulley swaps done to increase boost when a motor is in place to handle it. I recommend long tube headers if you don't have them already.
Keep an eye on our (TTi) Twin Turbo kits as the install base increases.
Best of Luck :)
:cheers:
[Modified by billreid1@***.net, 8:48 PM 4/22/2003]
Old Apr 22, 2003 | 09:59 PM
BLOWN IN NC's Avatar
BLOWN IN NC
Default Re: Forced induction recommendations needed: (billreid1@***.net)
Yeah, be glad it wasn't a single turbo veilside!
Old Apr 22, 2003 | 10:50 PM
BLUTHUNDER's Avatar
BLUTHUNDER
After getting blown away by a Toyota Supra TT in my boner stock MN6 LS1 98 coupe I'm feelin the need for more power. I decide to build a motor?
Eric , i had to laugh at your story..Because it was VERY similiar to mine..Only difference is I was spanked by a Supercharged Saleen Mustang.
That day i swore I would never let another FORD embarass me again :)
I went ATI !
Good Luck
:cheers:
Jeff
Old Apr 22, 2003 | 11:41 PM
JAvery20's Avatar
JAvery20
Default Re: Forced induction recommendations needed: (BLUTHUNDER)
Hehe :yesnod:
Old Apr 24, 2003 | 02:20 PM
Devil Dog's Avatar
Devil Dog
Then you better pick your races wisely,because there are some serious Mustangs out there.
ericdwong: Since you are starting from scratch I would go with a turbosystem, Turbo Technology makes a affordable twin turbo kit and a turbo is definitely the best power adder you can buy, and its easy to upgrade for future endeavors..
www.turbotechnologyinc.com
[Modified by Devil Dog, 7:33 PM 4/24/2003]
Old Apr 24, 2003 | 02:34 PM
hogurt's Avatar
hogurt
Default Re: Forced induction recommendations needed: (Devil Dog)
:iagree: There are some SICK fast Mustangs. However, unless they have dumped some very serious cash into the chassis and done something to put the PIG on a diet, it will be difficult for a Mustang to keep up. :yesnod:
That being said, if they are squirtin', you might be hurtin'! :lol:
I have read about one of the new '03 Cobras (Nitrous Pete) running in the 9's. :crazy:
However, once the Vette is running FI, there are very few cars that can keep up. :D :D
Old Apr 24, 2003 | 04:32 PM
YELLOHHH's Avatar
YELLOHHH
Don't they run in the high 12's?
Greg
:steering:
Old Apr 24, 2003 | 04:56 PM
STAGED's Avatar
STAGED
Default Re: Forced induction recommendations needed: (YELLOHHH)
Try a Vortech-aftercooled pkg; stock hood, smooth idle, progressive boost curve, and quiet operation make for stealthy drama-free power. Check the aftercooler water pump operation periodically. Get an '01+ intake. Get a bigger/ported TB to reduce pressure drop to the manifold. Get better wires and high quality plugs gapped to ~ 0.035". Get higher flow cats (after you took care of tuning and your car was trouble-free/no ignition misses for a few weeks). After all is said and done you should pull easily from BPU'd Supras and be neck-neck with pump gas'd small to medium sized single turbo Supras running off-road downpipes. You should trap around 125 mph.
If you want more, add 1.8:1 roller rockers, better pushrods, and stronger valvesprings and set the rev limiter at 6700 rpm and make sure to back off timing a good bit after 6200 rpm as boost is rising beyond the safe mark for 10.1:1 CR. A high rev limiter is for the purpose of landing you in the real sweet spot of the powerband after an upshift for centrifugally S/C'd setups. My dart throw guess is you should trap near 130 mph in good air.
If you want more, think about doing a full engine buildup since your 1998 may be nearing borderline mileage for a power adder in a year or two.
[Modified by STAGED, 10:15 PM 4/24/2003]
To Forced induction recommendations needed:
