MSD WINDOW SWITCH WIRING
Apr 22, 2003 | 10:10 PM
OK GUYS,
WHERE DOES THE WHITE WIRE GO? WHERE IS THE TACH TERM? :withstupid:
Apr 22, 2003 | 11:05 PM
St. Jude Donor '05-'06-'08
Re: MSD WINDOW SWITCH WIRING (DEANOSMOD)
One of those goes to your computer.....if I remember correctly
Apr 23, 2003 | 01:57 PM
Where on the computor? The vette manuals show nothing. I'm lost :banghead:
Apr 24, 2003 | 12:39 AM
#10 SOLID WHITE wire..... oh there is a pic on this forum somewhere. hmmm
Apr 24, 2003 | 12:41 AM
#10 wire is correct. I also believe it is on the red connector of the PCM.
Also the white wire is the TACH wire if that is what you were asking.
Apr 24, 2003 | 01:22 PM
Re: MSD WINDOW SWITCH WIRING (z0sense)
yep, white #10. I found it under the passenger side dash. do a search for tach line. I got some pics and how I found it. I thought it was easier then pulling my wheel and fender well to get to my PCM.
Apr 24, 2003 | 05:04 PM
Re: MSD WINDOW SWITCH WIRING (Allgonoshow)
Could you post or email me those pics and how you found it. I was looking down that IPC harness, but gave up rather quickly :D Just to many wires :D
I am putting in another TNT kit for a freind and would rather go that route than splicing into or soldering the pcm itty bitty wire again.
:cheers:
Apr 24, 2003 | 05:21 PM
Cruise-In III Veteran
St. Jude Donor '11
Here is the pics on how to find it behind your passenger front wheel, scroll about 3/4 down.
http://forums.corvetteforum.com/zerothread?id=380644
You can click on the pics to make them bigger. :cheers:
Apr 24, 2003 | 07:47 PM
Re: MSD WINDOW SWITCH WIRING (intel55)
OK, here is the link to my post from back then. If your not afraid of digging in some wires then goto it. At the bottom of the post is the link to a pic.
http://forums.corvetteforum.com/zerothread?id=380488
Apr 24, 2003 | 08:51 PM
