Headers or no headers
Comments?
Thanks,
Darin
[Modified by dbvettez06, 11:38 AM 5/6/2003]
Here's a thread where a forum member added LGM headers to a Magnacharger on his Z06, presumably one of the better ones out there, and the results you can view to see what you think. I'm unclear what changes were made to the cats at the same time? :confused:
http://forums.corvetteforum.com/zerothread?id=502832
If it were me and I was putting that much more $$ on top of the SC, it'd be in a cam, instead. Just my $0.02. Good luck. :seeya
[Modified by SteveL2, 12:45 PM 5/6/2003]
Labor........~$400
Tune.........~$500. If you're doing it all at the same time, you may not incur this cost.
Otherwise, if you're adding it after the SC is installed & tuned, you're looking at ~$2000 for a gain of 15-20hp.
Been there , done that & would not do it again.
Cam swap is a better investment. Blower cam for ~$300+, install ~$600+. For about $1000 you get 20-30hp.
Labor........~$400
Been there , done that & would not do it again. . . .
Labor........~$400
Bob, I thank you for the post. So far, it's the only one that seems to have real #s to support it. :cheers:
then he got some headers:
TTS headers on GP sale: $1000
labor (did it himself): $0
dyno tune (didn't bother with this): $0
the look on everybody's faces when he (repeatedly) dynoed 335 rwhp and 350 rwtq: PRICELESS!
note that he gained ~25 rwhp and 20 rwtq, and had ALOT more area under the curve. plus, his car sounds nasty as hell at WOT with headers and loudmouth.
i really think the key is which headers you buy. i.e. (obviously) don't buy restrictive 1 5/8" headers for a superstroker motor. and conversely, don't buy 1 7/8" headers for a stock ls1. my buddy with the TTS picked up big numbers, but i have another friend with very similar bolt-ons who didn't pick up jack (+16rwhp, +20rwtq, but only at upper rpms, and lost alot of area under the curve at low rpms) under the curve after installing TPIS headers.
i really dunno. its starting to look like c5 headers are (literally) a crap shoot.
[Modified by tattooed, 11:50 PM 5/6/2003]
ok, i fixed the incorrect #s for you Joey. thanks for poiting out that i was about 100 off on your hp and tq. hopefully everybody realized that the 210 should have been a 310. :)
[Modified by tattooed, 12:23 PM 5/7/2003]
note that he gained 25 rwhp and 35 rwtq, and had ALOT more area under the curve. plus, his car sounds nasty as hell at WOT with headers and loudmouth.
i really think the key is which headers you buy. i.e. (obviously) don't buy restrictive 1 5/8" headers for a superstroker motor. and conversely, don't buy 1 7/8" headers for a stock ls1. my buddy with the TTS picked up big numbers, but i have another friend with very similar bolt-ons who didn't pick up jack (+3rwhp, +5rwtq, but lost area under the curve at low rpms) after installing TPIS headers.
They also did the same set up on a 2002 c-5 convertible with a b-b exhaust (route 66), and gained 24 horsepower at rear wheels.
On a N/A car you can add headers & gain power w/o tunning. On SC'd vehicle you'll definitively need to retuned it. I LOST 10 RWHP adding the FLP header system to my ATI SC'd C5 ( from overcompensation of fuel. Car run pig rich) . That said if you intend to go well over 500rwhp then a set of headers will be well worth it.
For a magnuson, I still say blower cam swap is a much better investment.
Compare apple to apple :D
[Modified by boblackhardtop, 10:08 PM 5/7/2003]
On the other hand, if someone also wants to improve the sound, then they simply have to decide whether that's worth it to them. :seeya
[Modified by SteveL2, 4:20 PM 5/7/2003]
2002 LS1 with borla stingers and the magnuson 407.8 rwhp. baselined at 308. No headers...looks pretty good to me.
D.
D.
When you go back, ask John where my "extra" 15 hp went for me? :troll :jester
