MPH NOS Switch??
Old May 7, 2003 | 01:02 PM
urpow's Avatar
urpow
Default MPH NOS Switch??
Hey Anyone know if there is a MPH NOS switch??
Also, whats the most cleaness setup for a C5... with regards to all the switch panels/gauges from NX... any pictures?
Thanks!
Old May 7, 2003 | 02:11 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: MPH NOS Switch?? (urpow)
I dont think there is a MPH activated switch. I would use a RPM window switch and set the RPMs to the designated speed in the desired gear.
Here is my N2O guage, switch panel and shiftlight
Old May 7, 2003 | 02:18 PM
urpow's Avatar
urpow
Default Re: MPH NOS Switch?? (ICULUKN-C5)
How do I set a particular gear switch??
Allgonoshow's Avatar
Allgonoshow
Maybee a window switch with a MPH activation built into it might be cool. What are you trying to acheive with the MPH activation?
Old May 7, 2003 | 02:21 PM
urpow's Avatar
urpow
Default Re: MPH NOS Switch?? (Allgonoshow)
Something like 50 shots from 0-60 mph, and 100 shot after that that... just to improve traction... of course this needs a dual stage kit...
Old May 7, 2003 | 03:51 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Get a progressive controller. This will allow you to use time to regulate the N2O. For example, time yourself from 0 to 50. Lets say it takes 4 seconds. Then set your N2O controller to only spray the 50 shot for 0 to 4 second, then 75 shot for the next 2 seconds. 100 for the next 2 and a 150 for the next 2 seconds. If you have a controller you dont need to do a dual stage system, if you dont want to.
Old May 8, 2003 | 02:19 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Is that an electronic gauge or mechanical?
[Modified by 5 Liter Eater, 7:21 PM 5/8/2003]
Old May 8, 2003 | 02:32 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: MPH NOS Switch?? (5 Liter Eater)
electrical
To MPH NOS Switch??
