Between a Cartek, MTI 427cid and a LPE stage 1 turbo kit...
If both conversion cost the same...
-Wich car makes more power?
-Wich car is smoother?
-Wich is faster in 1/4 and wich for top end?
If are you, which one you prefer and why?
Just want a opinion of everyone, since I'm from overseas and don't have any idea to how is the feeling of those cars.
Re: Wich conversion do you prefer and why?? (Greenbeast)
LPE TT stage 1...faster and much smoother. I have had big motor C5 and all of my buddys have big motor C5... They are great but with out using N.O.S the LPE TT stage 1 is a little faster and alot smoother. :yesnod:
Re: Wich conversion do you prefer and why?? (DJ Self)
All 3 of those packages should put you near 500RWHP ... The LPE TT will be the most reliable ... but the MTI and Cartek will have a greater upgrade possiblity ... but if you can be happy with 500RWHP go to LPE ... and then in 2 years after the warranty is over ... a boost controller should get you 550RWHP ...
All 3 of the tuners are great ... for you in Panama ... 21st Century Motorsports(LPE Authorized Installer) and MTI are closer ... so that could play into your decision ....
Not sure about MTI but the LPE TT Power is as smooth as a baby's butt. Also, you actually have a stage II (650 hp) under the hood with only a few modifications.
