Purge Valve Installation Help
Old May 26, 2003 | 01:42 PM
BadMedcn's Avatar
BadMedcn
Default Purge Valve Installation Help
Unfortunately I have misplaced the instructions for installation of the purge valve in a NOS 5177 system. I have the NOS hooked up and functioning very well, just need to know where the purge solenoid goes in relation to the rest. Anyone able to help? :confused:
Old May 26, 2003 | 03:28 PM
VetteNoob's Avatar
VetteNoob
Default Re: Purge Valve Installation Help (BadMedcn)
It's all about the same. Maybe this will help out some.
http://www.dynotune.org/store/Script...structions.htm
I have some pics of the install on my C4 in the C4 Nitrous Section. Good luck.
Old May 26, 2003 | 04:09 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Purge Valve Installation Help (VetteNoob)
purge vale goes on the out of the solenoid on a NX kit. The 4an line goes into the one side, the line to the nossle goes out the bottom, and the purge comes out the other side to a vent line. HTH.
Old May 26, 2003 | 11:15 PM
WILDONETHIRTYSEVEN's Avatar
WILDONETHIRTYSEVEN
Default Re: Purge Valve Installation Help (ICULUKN-C5)
:iagree: :thumbs:
Old May 27, 2003 | 08:26 PM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
you don't really need a purge on a dry kit....but if you want one for effect, it connects directly to the first solinoid where the 4an line would normally go, so basically you will have 3 solinoids in a row the first being the purge solinoid....good luck
To Purge Valve Installation Help
