Plastic Air Bridge
Hi Jeff,
I have a few but they arent that good. I will go take a few and email them to you.
Looks like this is the way to go.
What do you think about using the same Piping to run the Airfilter to the SC?
:cheers:
Jeff
I was going to order a tube here for the same reason, but have not gotten around to it yet.
http://www.mandrelbending.com/
It looks like they can make you just about anything you would need.
Phil, would you mind emailing pics to me also? Email addy: teresayharris@yahoo.com. Thanks in advance.
Phil, thanks for the pics !
:cheers: Jeff
:cheers: Jeff
The problem with using a tube like that for the supercharger is clearing the radiator since its so close to the inlet. Thats what is nice about the procharger duct is that its conformed to fit over the radiator. The duct is narrow for clearance over the radiator but its also wide to maintain the same amount of area. A tube similar to what I used for the inlet into the engine could be used but the radiator would have to be lowered more, at least mine would have to be anyway. Besides, the inlet into the supercharger isnt pressurized so its not that big of a deal.
[Modified by Av8ter, 7:13 AM 6/5/2003]
Phil ,
I measured the circumference of my current airbridge and it's 12 Inches.. Do you know what size Pipe I need to order ?
3 " seems small:confused:
:cheers:
Jeff
:cheers:
Jeff
Phil ,
3 " seems small
Jeff
3 " seems small
Jeff
Can someone please e-mail me a pic and more info on this mod. I am having the same problem with keeping the air bridge connected to the MAF.
I was able to watch the plastic air bridge today when the twin turbo's were making around 7lbs of boost. The bridge actually starts to buldge out about a 1/2 an inch in the middle section under boost and then when the throttle is released BOV go off and vacuum is created the middle section looks like it is going to implode. I think it is only a matter of time before these expansion and contraction cycles cause the bridge to fail, after seeing what I did today I got some real serious concerns. I am turning up the boost in a couple of weeks and will not run the car with the plastic air bridge until this is fixed. I'm telling ya it was freaky watching the air bridge it was like it was a lung breathing in and out. Shino and King Pin I know you have the same setup as me I would look into doing this also.
