N20 progressive controller users, need some advice
I may be wrong anyone know?
I will try to make it :boxing
no but you must be smokin some of that to try and call my bluff on about every single detail of my car! of course i didnt think i would hook with that combo, my car was originally setup for NA, like my sig says I was going for the NA record, but now I want to do both so I've got to scale it down some. ANYTHING ELSE???? :rolleyes:
What class will you be running at the Southern Shootout?
I was looking at the rules and classes on ls1 tech and was wondering where your car would fit in. I am trying to attend and will be in the MS/PA class.
There is mention that they require full interior as well min weight requirements depending on class.
Hope to see ya there!! :cheers:
Paul
May be you could run the Outlaw class.
Good Luck
THE FOLLOWING GENERAL RULES FOR THE THUNDER RACING SOUTHERN SHOOTOUT APPLY TO ALL RACERS:
(1) All NHRA Safety Rules for your ET and speed will be enforced.
(2) Rules apply to all F-bodys (1967-present) and Y-Bodies (1953-present) with factory type EFI (No Carburetors)
(3) All rules apply to GM Engines with 4.4" Bore Centers (No Big Blocks)
(4) Full interior is required, including two front seats and carpet. (Back seats not required.)
(5) Ballast may be added to make weight requirements per safety rules.
(6) Minimum weights are with Driver. Scales at No Problem Raceway Park will be used to weigh all entrants. All classes except Pro-Stock and Pro-Outlaw must cross the scales under their own power. For Pro-Stock and Pro-Outlaw any car that must be towed to the scales may only use a golf cart or four-wheeler with two crew members.)
(7) Rear suspension on all cars must have stock-type springs and shocks in stock configuration.
(8) No nitro-methane or alcohol fuels allowed for any class.
(9) Please be prepared to allow for inspection of your engine. This especially applies to class winners; however, all racers are potentially subject to inspection to verify cubic inches, presence of ported cylinder heads, etc. Please e-mail if you have any questions about this.
(10) Each racer is ultimately responsible for ensuring that they are competing in the correct class. Please read the rules below carefully to see which class best suits your car's combination. We will be happy to help you determine this if you have any questions, just e-mail us @ shootout@thunderracing.com.
Street Stock Automatic (SS/A)
Street Stock Manual (SS/M)
Quick Stock (Q/S)
Modified Stock (M/S)
Modified Stock Power Adder (MS/PA)
Pro-Stock (P/S)
Pro-Outlaw (P/O)
Bracket Race
Truck Eliminator Class
Pro-Outlaw Class (P/O)
F-body and Corvette Race
PAYOUTS: WINNER $1500
RUNNER-UP $500
SEMI-FINALIST (2) $150
MINIMUM FIELD FOR PAYOUT:
8
ENTRY FEE:
$95.00 for car & driver for both days of event
TREE:
.400 Pro-Tree
MINIMUM WEIGHT w/ DRIVER (RACE WEIGHT):
3000 lbs
TIRES:
10.5 Tread-Width Slicks
13.5 Sidewall DOT
30" Tire Height Maximum
TRANSMISSION:
-Any Transmission
-Trans-Brakes allowed
POWER ADDERS:
Multiple Power Adders Allowed
MAXIMUM CUBIC INCHES:
-455 ci
GENERAL RULES FOR THIS CLASS:
- Any small block to 455 CI
- DFI or aftermarket computers allowed
