Single vs Dual Intercoolers
Old Aug 4, 2003 | 11:36 AM
kromberg's Avatar
kromberg
Default Single vs Dual Intercoolers
How much difference is there between the two? I have heard that singles are more efficient, how much rwhp difference is there? I have also heard that the dual units require more plumbing, how much does it increase the install complexity? Lastly, does ATI and Vortech offer both versions?
Keith
Old Aug 4, 2003 | 11:45 AM
QuickSilver2002's Avatar
QuickSilver2002
Default Re: Single vs Dual Intercoolers (kromberg)
Take a look at this post for some data
http://forums.corvetteforum.com/zerothread?id=530499
Just to clarify, the #s in this post are based on two modifications to the ATI kit. The air filter was moved up front and the dual intercoolers were replaced with a single front mount.
There is another post out there about HP change, you will have to search.
Old Aug 4, 2003 | 12:12 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Single vs Dual Intercoolers (QuickSilver2002)
I think andy said he got 40 more RWHP with a single.
Old Aug 4, 2003 | 12:54 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Single vs Dual Intercoolers (ICULUKN-C5)
Single intercooler will yeild:
1) Higher cooling efficiency due to increased surface
2) less pressure drop across the core(more boost at the motor)
Phillip
Old Aug 4, 2003 | 01:21 PM
kromberg's Avatar
kromberg
Default Re: Single vs Dual Intercoolers (Phil97SVT)
So does the single intercooler go infront of the radiator? Any 'special' modification needed to the radiator or an aftermarket one needed?
Keith
Old Aug 4, 2003 | 01:28 PM
BrainDrain_dx's Avatar
BrainDrain_dx
In front of the radiator right on top of the ac condesor. You need to modify the radiator mount not the actuall radiator itself. YOu have to cut the lower radiator support bar off the frame savers. Bend the frame savers closer together and weld it back on farther forward on the car so the radiator will lay down more. I know more when I finish next week.
[Modified by BrainDrain_dx, 12:28 PM 8/4/2003]
Old Aug 4, 2003 | 02:02 PM
blu00rdstr's Avatar
blu00rdstr
I did before/after dynotune with the only change being the A&A Single Intercooler(FMIC on dyno). I gained 42rwhp before it started missing at 6,000rpm (125mph). I believe I missed about another 20rwhp on the dynosheet because I didn't know about the miss until I started driving it. I fixed the miss with plugs and wires.
This is a photo of the HP/MPH, Baseline is 480, FMIC is 490, FMIC tuned is 522 (measured at the 125mph line).
This is a photo of the TQ/RPM, Baseline is 438, FMIC is 442, FMIC tuned is 472.
[Modified by blu00rdstr, 11:39 AM 8/4/2003]
Old Aug 4, 2003 | 05:55 PM
Red C5's Avatar
Red C5
Default Re: Single vs Dual Intercoolers (blu00rdstr)
So the gain is actually from aggressive tuning is what it sounds like. The hp/tq pickup without tuning wasn't all that great. Looks like the A/F is much leaner after the FMIC.
Old Aug 4, 2003 | 06:06 PM
blu00rdstr's Avatar
blu00rdstr
Default Re: Single vs Dual Intercoolers (Red C5)
It was set a full point leaner after FMIC. The 'before' dynotune was to their best, according to MMS.
Old Aug 4, 2003 | 06:26 PM
Phil97SVT's Avatar
Phil97SVT
The car was richened up significantly. There is still a few ponies left on the table...when the intake charge is colder you can lead the spark more.
Phillip :cheers:
Old Aug 4, 2003 | 07:52 PM
Red C5's Avatar
Red C5
Phillip :cheers:
Maybe I am just looking at the posted dyno sheet wrong, but it looks like he went from somewhere around 11:1 to 12:1 + A/F :confused:
Old Aug 4, 2003 | 08:58 PM
blu00rdstr's Avatar
blu00rdstr
From the hazy copies I have, it looks like 'before FMIC' was 12.5, and 'after FMIC' is about 13.3 or 13.5. Andy told me MMS had to lean it out a full point after the FMIC.
I found my invoice, MMS performed:
<li>Computer reprogram LS1
<li>Dyno Tuning first hour, inc wide band
<li>Dyno Tuning additional hour
<li>Computer retune LS1
Old Aug 4, 2003 | 09:22 PM
Red C5's Avatar
Red C5
I would think that is too lean for a FI motor. I'm not as smart as most of the people around here. I thought I read that on a blown car, the most you would wnat is 12-5-12.8 :confused: :confused:
Old Aug 4, 2003 | 11:32 PM
blu00rdstr's Avatar
blu00rdstr
Well, let me put it this way: I lost a cylinder and am about to begin assembling the parts I bought.
Old Aug 4, 2003 | 11:36 PM
QuickSilver2002
Well, unfortunately that motor is now literally blown. So I guess it may have been a little lean. There is no doubt that leaning it out produces more power, but the stock pistons and ringlands just can’t take it for long.
Old Aug 5, 2003 | 09:12 AM
kromberg's Avatar
kromberg
Here is another question: Is the Vortech aftercooler as efficient as the ATI single intercooler? Also is the charge temp a bigger issue with cars that have a higher compression ratio?
Keith
Old Aug 5, 2003 | 02:17 PM
QuickSilver2002
You will have a tough time getting a clear answer on this. I would guess that a big single air to air is more efficient, but the aftercooler may perform just as well with cool water. I would guess the big single air to air would be more efficient overall. This is just a guess.
Another tough one to answer with a simple yes/no. Detonation sensitivity is increased with pressure, heat, and fuel instability. A higher compression motor is going to be generally more sensitive than a low compression motor. This is why you will see the recommended boost levels being lower for the ls6 vs the ls1.On the other hand, a high compression motor needs less boost to make the same power. You can actually create more power with lower static pressure and higher dynamic pressure via boost, but you will sacrifice drivability in non boost conditions and the internals have to be stonger to deal with the higher pressure and heat.
[Modified by QuickSilver2002, 7:19 PM 8/5/2003]
To Single vs Dual Intercoolers
