What you be a good optimal for a S/C application? I am planning on runing a 408 LQ4 block with with -15cc pistons and LQ4 heads with 75cc chambers. This should give a static compression ratio of 9.3:1. With this compression ratio and having the stroker, would it still give somewhat 'ok' performance under non boost conditions, aka low rpms? Lastly, would this be able to run about 13 psi of boost using ARP head studs?
I would say a C.R. of about 9:1 would work out pretty good, you don't want to go too low because your off-boost performance will be sluggish, your 9.3:1 should work great and give you solid off-boost performance. :yesnod:
Andy typically builds 9.8:1 with a -2cc piston dish. He pointed me to an online compression calculation tool at http://www.Rosspistons.com.
Stock motor is 3.905" bore & 3.622" stroke. Head chamber (A&A S2 CNC heads) is 71cc, I'm not sure what stock is. Gasket thickness is .050" but type in .040" since the piston sticks up .010". Zero deck on the calculator is .0001. My pistons have a -8.6cc dish. For me this works out by hand to 8.9:1, but the online calculator has me at 9.1:1
Watch gasket compressed thickness and pistons, in/out of the hole above deck. Also gasket bore.
.010 out of the hole will give you good quench, but may be dangerous depending on the compressed gasket thickness. Also if you ever have to deck the block in the future, the pistons will be too high.
