ATI vs. Vortech
Re: ATI vs. Vortech (YELLOHHH)
I'd rather ********** with an handful of broken glass than put myself through what MANY ATI guys have gone through.
Re: ATI vs. Vortech (hogurt)
Both systems are strong. Unfortunately, most people will just vote for the one they have!
The key is getting a good installer/tuner! :cheers:
With the alignment issue out of the way we had to deal with another belt issue. When the car would hit the rev limiter, it would bounce the belt off. This would result in one hell of a mess. Phil ended up going to a slightly shorter belt then the one Vortech supplied with the kit. The new, shorter belt put the tensioner right where it should be with a new belt.
So far the car has run great with no problems. Phil and Jeromy at DTE did a great job working through all the problems. As stated before, a good tuner really does make all the differance.
Re: ATI vs. Vortech (VortechC5)
Oh no, two members with VortechC5 for a user name. This will be confusing...
Platinum Supporting Vendor
Re: ATI vs. Vortech (MARK's_C5TT)
I probably have installed more of both than just about anyone in the country. I do about 3:1 Prochargers to Vortechs. The Vortech is more labor intensive but works great just the way it is supplied from Vortech. I believe I was the first tuner to install one, other than Vortech. There were a few glitches that I discussed with Chris ( the head engineer that designed the system) and they were fixed right away. If you're looking for 500 RWHP the Vortech is great.
If you have aspirations of 600 RWHP or a big inch motoir with boost, then the Procharger with some modifications is the ticket. They also make a great system if you're satisfied with 500 RWHP.
I may be biased but I think I have finally devised a bracket and pulley sytem that will support big inch motors or high boost levels that really fixes all the belt and heating issues. I have been working stedily for the last 2 years on this system. I have 5 of them out there now and none show any signs of belt slip at over 600 RWHP. I'm just working on the aesthetics to make it look as good as it performs. All the bracketry, intercoolers, tubing, pulleys, tensioners etc. are custom built for my system and, I believe, have come together as the best supercharger system availablefor the C5, period.
I'm working on an F1R system for the truly sick. I think that over 700 RWHP in a streetable package is just around the corner.
As an aside, my system is also less expensive than the others as I have made the system much simpler as well as efficient. $4995 buys you a complete system with all the upgrades.
Just though I'd add my .02
:cheers:
:cheers:
Re: ATI vs. Vortech (Go Low)
this is like arguing with Irish Catholics and Irish Protestants about which religion is better. and i've already seen more b.s. in this thread than you'll find three feet up a bull's butt.
Re: ATI vs. Vortech (Andy@AandACorvette)
:cheers:
:cheers:
Besides all the above, working with a vendor such as Andy gives you access to his wealth of knowledge concerning the install and operation of the blower system. I'll be certain to post my opinions concerning the quality of Andy's kit, ease (or lack thereof) of install, and lastly and probably most important..... TUNING AND DRIVING IMPRESSIONS!! :auto:
This should be fun. :party:
1 Post
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Re: ATI vs. Vortech (Vortech C5)
Quick question. Who did your install and what did it cost? Were any additions necessary / recommended such as headers, fuel pump, injectors, etc? I am seriously considering the Vortech due to smog issues (CA). Thanks for the info. D
:D
:D
I noticed that the supercharger is in place of the alternator, and power steering pump, and yata yata.. do they come with custom brackets?
Because if you guys have the old corvette accessories, I would be willing to take them off your hands..
I need all corvette accessories to fit this LS1 in my Sonoma.. :)
:steering:
:steering:
