Misfire??
Old Oct 3, 2003 | 08:52 PM
motorokie's Avatar
motorokie
Default Misfire??
I am new to posting, but I have been a forum member since I bought my 99 MN6 coupe over two years ago. The car was completely stock until last month when I opted for a Procharger P-1SC. I still even have the stock exhaust. The car was tuned by Ed Wright and I want to share the before and after results and get some opinions. Stock SAE RWHP was 299.6 and stock torque was 311.1. After the S/C installation, the RWHP jumped to 440 at 5500 rpm and the torque was 434.5. Above 5500 the engine had some misfiring but then smoothed out and topped out at 477.5 HP at 6400 rpm with 7 pounds of boost. I can duplicate the misfiring on the street and Ed’s people think it is ignition related (stock metal shields arcing). It feels like it does when the rev limiter kicks in. I have ordered some MSD wires, but after reading on the forum I am wondering if I might have fuel delivery problems. Has anybody experienced a similar situation after installing a supercharger? Sorry for the long post!
Old Oct 3, 2003 | 09:54 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Re: Misfire?? (motorokie)
I'd start with plugs and wires -- it's cheaper than any other route. It doesn't seem like the DIC would report misfires if you were just running too lean. I'm willing to bet it knows when it fires but no spark occurs.
Old Oct 3, 2003 | 09:57 PM
99C5ragtop's Avatar
99C5ragtop
Without driving the car it's hard to say...but after my Mag/heads/cam/long tube etc install at Cartek I drove for about two weeks and it was solid...then I noticed hesitation/misfire....turned out to be a bad plug wire....replaced the plug wires and a month later same thing happened...finally nailed it down to high temps melting the plug wires....bought a new set of wires and the koolsox insulators and have been AOK ever since.
:cheers:
Old Oct 4, 2003 | 01:22 AM
SleepieAce's Avatar
SleepieAce
From: Kentucky basketball is life the rest is just details
Default Re: Misfire?? (99C5ragtop)
Good numbers. :thumbs: Go with plugs and wires first. I don't know if you still have stock plugs in, but I had the same kind of problem with the high rpms due to the increased air coming in blowing out the spark. It sounded exactly like the rev limiter. I replaced the stock plugs with NGK TR6 plugs gapped at .35 and the problem went away. I'd bet you're having the same problem. :cheers:
Old Oct 7, 2003 | 07:19 AM
jpas's Avatar
jpas
Let us know if the plugs solved your issues.
Old Oct 7, 2003 | 07:44 AM
motorokie's Avatar
motorokie
Default Re: Misfire?? (jpas)
Will do! I got my new MSD plug wires yesterday. I think I will install those before I change the plugs (they are only 2 week old Autolite copper) and see if the wires fix it. I want to know what the problem actually was (is).
Old Oct 7, 2003 | 05:17 PM
SleepieAce's Avatar
SleepieAce
:thumbs: :lurk:
To Misfire??
