Calling All ATI Experts
The point is or how you look at it you have a nice blower and yes back pressure will cause higher boost and for example I am running 11psi at 5800rpm with full length headers no cats no muffs 3 inch pipe all the way back and all in all my belt is slipping...but one theory I have as well is the differential gears in the back...for example I have 3:73's and since my motor spins so fast with those gear I do believe my belt slips till it catches up...I know a guy with stock gears and there is no slippage on his car and he makes a lot of boost on a big pulley. So be happy for the blower size and it only leaves you room when rebuilding the motor and wanting to make killer power if that is your goal :D
You have the right idea with the blower you have because if you decide to go with more power you have it...there is always an option i am working on is installing a BOV (blow off valve) and control the flow with that so i dont over boost like what you are talking..What my goal is to make 11psi at 2300rpm or little less and over spin the blower and any extra or over boost will be vented so in theory i make 11psi at 2300-6500rpm and any extra will be vented.
If so, is it a good strategy to run an 8PSI capable pulley and just shift at 7PSI, or is it better to run a 7PSI pulley and shift at redline?
on C4 forum black bart has a vette the is making 7psi at 2300rpm and then vents 15psi for the rest of the rpm
Tattooed: Nice to meet you too, I shall take you up on the offer when I get it going again. Your car is very SWEET! :)
[Modified by BrainDrain_dx, 4:55 PM 10/17/2003]
I should also point out that before the ATI kit was released I posted about the potential fan issue, which is a well-documented potential problem with all LS1 supercharger kits that require an aftermarket fan. Unless you've been living under a rock or are illiterate you were aware of this before you purchased the kit.
The turbocharger is "spooled" by exhaust gas, where the exhaust gas, and effectively the intake boost, is regulated by a "waste gate".
The "relief valve", or "blow off valve", or "surge valve", is meant to dump off boost that is the result of timing differences between the throttle position and exhaust pressure (or rpm in the case of a supercharger), to prevent the throttle body blade from bending, or the compressor from "stalling".
The problem with attempting to regulate boost using a post compressor device (like a "surge valve" for example) is that you usually wind up losing blower efficiency, and that its difficult to dial in. I've tried it before on many combinations, but the most successful have been when I used such devices to bleed off large amounts of boost on the street (because I'm too lazy to swap pulleys), and then disable them at the track.
I don't know why no one has raised this point, but from a longevity point of view the boost per say isn't a problem, its the potential for detonation. I'd leave the current pulley arrangement and pull a lot of timing out of the map (especially over 5800rpm), or consider running a smaller crank pulley (several are available). Another solution might be to trade compressors with someone, I'm sure there is someone here looking go upgrade to a D1.
[Modified by Av8ter, 11:13 PM 11/26/2003]
