nos levels
Nov 13, 2003 | 04:28 PM
nos levels
hey guys i'm on the fence right now and don't know which way to roll, i run 11.80's now with the mods listed below. what would a 125 wet kit do for my et's??????? :confused:
Nov 13, 2003 | 06:54 PM
St. Jude Donor '05-'06-'08
Re: nos levels (MC TORCH RED)
I see you are really looking into that Nos stuff!
Hey Bro, Im going to try 50 shoot 1st. and 100 if necesary. I was looking at ebay couple nights and there is some NX kits available....just go for it, I promise it will make you :D all the way down the track!
Nov 13, 2003 | 07:52 PM
Re: nos levels (mikes99corvette)
mike i allready have it, just have not sprayed it yet.. :confused:
Nov 13, 2003 | 10:46 PM
Go for 50 then move up.......... :thumbs:
Nov 13, 2003 | 11:55 PM
150 shot no less :eek:
Nov 15, 2003 | 09:20 AM
In that case go 200.... :D and let me know the results.......JUST KIDDING, DONT DO IT!!!!!!
Nov 15, 2003 | 11:01 AM
i have a buddy with a stock bottom end 99 cp. he sprayed 200 shot and ran 10.60's at hallsville and the car still drives perfect??????he went from 12.10's to 10.60's with the 200 shot. :eek: :eek: :eek:
Nov 15, 2003 | 11:58 AM
200 is playing with fire is you are not direct port... You greatly increase your chance of puddling the intake if you go bigger than 150 on a fogger system.
Nov 17, 2003 | 08:05 PM
MC:
Should be good for at least a second. You may be tire limited with the 275 Nitto's though.
The Vipers won't know what hit em! :chevy
Keep us posted.
Nov 17, 2003 | 08:44 PM
Re: nos levels (bogielake)
:lol: vipers :U
Nov 17, 2003 | 10:33 PM
Hey Mitch.....anything over 150, I would highly recommend a better fuel pump. The stock fuel pump is good forr 100-125 shot. If it was me, I would even changed it at 150.
Nov 18, 2003 | 12:09 AM
thank's mike , all i need is a 100 shot , i think i can run 11.00's with a 100 shot. :eek:
Nov 18, 2003 | 12:15 AM
On nittos, you might not gain any ET. There is chance you will smoke the tires in first and second gear.
I suggest a 100 - 125 shot, 150 max.
If you can hook up with the 150 shot, u will be in the 10s.
Nov 18, 2003 | 12:52 AM
Re: nos levels (kumar75150)
i will not be spraying in 1st gear ever, only 2nd and 3rd.............a-4
Nov 18, 2003 | 01:08 AM
Only way to find out is to do it.
I would be shocked if Nittos were able to handle a 150 shot.
Nov 18, 2003 | 01:19 AM
my plan is to spray only 100 shot max. and do it in 2nd and 3rd gears only , will the nittto's work then?????
Nov 18, 2003 | 02:45 AM
how much power are you making now? I doubt Nittos will hold anything over 400 but I dont have experience with automatics.
Nov 18, 2003 | 10:25 AM
360hp to 370hp at the rear wheels...it hooks great now leaving a 2500rpm's 1.66 60fts.
Nov 19, 2003 | 02:33 AM
Nittos should be fine for anything you throw at them.
BFG's are good too. But I think they are all the same!!!! It is all in the driver!
Nov 19, 2003 | 02:31 PM
Re: nos levels (z0sense)
mitch, mitch, mitch....
NEVER SATISFIED
:thumbs:
