Deep discounts for Vortech and ATI superchargers
Location: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
1 Post
St. Jude Donor '06-'07
We are offering DEEP discounts on all Vortech and ATI kits that we carry. These prices are good through Sunday evening, November 30th. Please e-mail tbyrne@tbyrne.com or give us a call at 1-877-4-TBYRNE for pricing.
Vortech -
Vortech uses the V-2 SC-Trim supercharger with the Super Quiet gears, for nearly silent operation of the supercharger under idle and full throttle applications. This system comes with everything you need to bolt it on, including high capacity replacement fuel injectors, hi flow fuel pump assembly with wiring harness, a secondary cog drive system and more. A handheld ECM re-programmer is included with the kit to enable fuel and timing curve changes and to make operation hassle free. This kit will show you a 140+ horsepower gain to the rear wheels!
V2 CCW rotation SC-trim SQ supercharger uses 6-rib 3.60" pulley and secondary cog drive (30T/34T) producing 6.5 psi at 6500 rpm
Air/water charge air cooler (closed loop) increases performance and reliability of supercharger system and includes:
Supercharger drive system includes all necessary belts and pulleys
Cast aluminum mounting bracket mounts power steering pump and supercharger
Anodized billet mounting plate assembly relocates alternator and spring tensioner
Bosch compressor bypass valve
Molded inlet duct retains stock air box/ MAF location
Welded charge air cooler core assembly with aluminum discharge tube, Bosch compressor bypass valve, silicone sleeves and stainless steel hose clamps
Charge air cooler water storage tank with hoses, clamps and plumbing
Compact water circulation pump for closed loop cooling
Water cooler
Hand-held programmer controls ignition timing and fuel enrichment
Fuel system upgrade includes 42 lb/hr fuel injectors
Oil drain and oil feed assemblies allow for maintenance free operation
Programming is available for the 2001-'03 Z06. 2004 programming will be available soon.
ATI -
The new H.O. Intercooled ProCharger system for 1997-2003 C6/Z06 Corvette applications is now available. It produces an industry-leading 535 horsepower on stock motors running pump gas. Featuring the self-contained P-1SC-1 ProCharger and twin highflow intercooler system as standard equipment, this recently introduced ProCharger system produces the largest power gains available for the LS1 motor. The system is 100% complete, and a polished finish for the supercharger and bracket assembly, as well as a three-year supercharger warranty, are also standard.
This system features the easiest installation of any intercooled forced induction system for the C5, and both the supercharger and intercooler system are compatible with additional power upgrades, as they both support over 750 horsepower.
This intercooled supercharger system creates 535 horsepower on an LS1 motor with 7 psi of highly efficient intercooled boost. The self-contained P-1SC-1 ProCharger (gear driven, with no need to punch a hole in the oil pan) and twin highflow intercooler system together produce the coolest charge air temperatures and greatest reliable power gains, as well as largest hp gains per pound of boost. The 7 psi pulley is standard, and a 5 psi pulley (which produces 490 hp) is also available. In addition to the components mentioned above, the HO Intercooled system also includes eight 38 lb/hr fuel injectors.
For those with highly modified motors and/or wishing to do custom tuning, an Intercooled Serpentine Race Kit is also available, which includes the D-1SC ProCharger and excludes the fuel injectors, but is otherwise identical to the HO.
We are now offering custom programming for the ATI superchargers. The program will be set up for the supercharger and any other modifications that you have on the vehicle. The cost for this will be $450. You will just need to send your PCM in for programming when you start your install.
Tom
Vortech -
Water cooler
ATI -
Tom
1 Post
Re: Deep discounts for Vortech and ATI superchargers (tbyrne)
Just saw your e-mail address in the other thread. Prices are on the way!
Just emailed you.....
Does the kit for the 2001 come with programming??? Your web page reads, "no programming included". If it does come with programming is it Vortech's programming???
:cheers:
:cheers:
1 Post
Re: Deep discounts for Vortech and ATI superchargers (SideStep)
I noticed that the site still had this note on it so that info was updated this morning. The 1999 model year is the only one that doesn't come with programming. Vortech has programming avaiable for the rest of them.
Hope this helps,
Tom
Hope this helps,
Tom
1 Post
Re: Deep discounts for Vortech and ATI superchargers (Ryan Bell)
email prices please
email prices please
Need your e-mail address :)
jamesryanbell@hotmail.com
thanks!
1 Post
Usually don't search the profiles. Your list is on the way!
1 Post
Re: Deep discounts for Vortech and ATI superchargers (02blueelectron)
sent this morning.
A little off topic but some of you guys might have one of these trucks. Vortech just came out with a kit for the 2003 Escalade, Denali and Silverado SS -
Vortech Engineering now has a supercharger with Aftercooler available for the 2003 Silverado SS, Cadillac Escalade and GMC Denali.
Kit details:
Flywheel horsepower/torque 6.0 Chevrolet SS truck:
stock (factory rating) ---345/380
supercharged (estimate based on % increase @ wheels)--- 465/494
Manifold boost pressure: 7-8 psig @ redline
Includes V2 S-trim supercharger with 3.33? driven pulley
Complete fuel system upgrade includes replacement fuel injectors, fuel lines and a high flow supplemental fuel pump with harness. Included hand-held programmer also controls ignition timing and fuel enrichment.
Molded air inlet ducting assembly features the Vortech logo, maintains factory appearance and employs the stock air box
Includes replacement engine coolant pipe and hose assembly
Oil drain and oil feed assemblies allow for maintenance free operation. Tools included for simple modification of oil pan for supercharger drain fitting installation
Factory appearing cast aluminum supercharger mounting bracket assembly includes idler, drive belt and all hardware
Air/water charge cooler system included. Charge cooler assembly includes:
a) Welded aluminum charge cooler core with discharge tubes, Bosch compressor bypass valve, silicone elbow, sleeves and stainless steel clamps
b) Charge cooler water storage tank with hoses, clamps and plumbing
c) Compact water circulation pump for closed loop cooling
d) Highly effective water cooler
Supercharger kit installation time is rated at 13-15 hours.
CARB E.O. D-213-19 has been assigned to this kit
It is strongly recommended an aftermarket transmission shift kit upgrade be installed.
They are also looking for a 2002 8.1 truck to test fit one of the new Paxton superchargers for that year. If anyone in CA has a 2002 8.1 and is interested in a kit let me know. I see what I can set up for you. Vortech will "take care of you" :)
Tom
Kit details:
Tom
