Clutch
Old Dec 3, 2003 | 02:35 AM
Callsign_Vega's Avatar
Callsign_Vega
Default Clutch
I plan on getting a 6-7psi SC or TC kit and am wondering if I will need a new clutch or will the stock one last a while and not slip?
Old Dec 3, 2003 | 10:22 AM
Sack Rat TT's Avatar
Sack Rat TT
Default Re: Clutch (Callsign_Vega)
Vega-You might get away keeping your clutch but not for very long. No power shifts or bonzai launches. How many miles on it? If 35 to 40,000 miles I would change it to at least a ZO-6 clutch or better. Replace the clutch slave actuator when you do the clutch and replace/bleed with fresh fluid as well. Good Luck
:smash: :smash:
Old Dec 3, 2003 | 02:25 PM
SleepieAce's Avatar
SleepieAce
From: Kentucky basketball is life the rest is just details
Default Re: Clutch (Sack Rat TT)
I've gotten away with it for 4K miles. Just occassionally dumping the clutch and powershifting, but I'll have to get one in the spring. :cheers:
Old Feb 6, 2004 | 07:39 AM
Callsign_Vega
It has 27k miles on it now. Is the clutch hard to replace on a C5? I have access to a lift.
Old Feb 6, 2004 | 11:23 AM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
if you have access to a lift it will be really easy. I just did mine w/ the car up on 4 jack stands, wasn't too bad, I have done worse jobs.
Old Feb 6, 2004 | 12:50 PM
GR8-LIFE's Avatar
GR8-LIFE
This is a tough one to answer. 21CMC put in a 2002 Z06 clutch when I went with an LPE STAGE I TT, around 6 PSI. A few months ago, I upgraded to a stage II and the base line boost is 8 PSI with max boost around 11-11.5 PSI (on pump gas). I still have my 2002 Z06 Clutch with absolutley no problems.
But IANFZ06, a CF member with an LPE STAGE I, has had free-play problems with his clutch since his install. I don't know exactly what his free-play issue is related to but I wantyed to atleast give you some information on his clutch issue being that he has an FI package. Here is IANFZ06's thread on his clutch issues and I hope this helps:
http://forums.corvetteforum.com/zerothread?id=739583
Old Feb 21, 2004 | 05:03 PM
Ianfz06's Avatar
Ianfz06
Default Re: Clutch (MARK's_C5TT)
Well the new slave and 'pig tail hose' go on this weekend.
I hope to report that all my freeplay issues are behind me, sometime next week!
:cheers:
Old Feb 22, 2004 | 10:27 AM
Sportsdude's Avatar
Sportsdude
I have stock clutch at present and will keep it until it fails.
To Clutch
