IT'S HERE......
Old Dec 20, 2003 | 05:02 PM
dads01dream's Avatar
dads01dream
Default IT'S HERE......
Well, sort of. I ordered my ATI setup from Andy @ A&A Corvette, here's what I got in order of receipt.
I received my D1-SC headunit from ATI like 3-4 weeks ago. The crank pinning tool showed up this past Thursday together with a K&N filter (don't know what it's for?), but there was no pin or drill bit. OH WELL, I think I need a HSS 1/4" drill bit and a solid stainless steel pin (1/4" dia x ?? length) Also, I don't have any directions for the crank pinning - Could someone tell me how deep to drill the crank to receive the pin?
Then yesterday (Friday) I received like 99% of the kit. I got the 6 rib pulley setup, radiator hoses to lay down the rad, all plumbing for the single I/C, my Racetronix fuel pump setup, the Vortech race BoV was mounted already and lastly a check valve for the PCV system (I think that's what it's for?) ..... BUT, I don't have the airbridge or the installation instructions to proceed with anything.
I think Andy is working on some new directions w/pictures for the install as he has apparently changed something to make the belt avoid slipping even more. While I'm waiting for a reply from Andy, I'll probably start the fuel system upgrade next weekend and will hopefully work on the install soon after I get Andy's installation manual.
Wish me the best!
:grouphug:
Old Dec 20, 2003 | 05:07 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: IT'S HERE...... (dads01dream)
The pin is 1/4 by .750 and you need to drill the hole .800 deep, If I had known this I could have sent a drill bit and ream to you with the LED's :crazy: Oh well, I know you'll get it straightened out. :cheers:
Old Dec 20, 2003 | 06:24 PM
dads01dream
Default Re: IT'S HERE...... (runamuk)
Hey run,
Thanks for the offer, but I'll just stop by an industrial supply shop and pickup the bit and a dowel pin. What's the reamer for?? I don't have the directions so I'm guessing it's to deburr the hole once drilled? I don't mind that the pin & drill bit weren't enclosed, Andy's not charging me for the pinning tool! :D I'm going to return the tool to him once I finish with it, guess I saved a few $$$'s :thumbs:
Thanks too for the LEDs, I'll be sure to let everyone know what I think once installed.
Old Dec 21, 2003 | 12:50 AM
SleepieAce's Avatar
SleepieAce
From: Kentucky basketball is life the rest is just details
Good luck! :thumbs: :cheers: :grouphug:
Old Dec 21, 2003 | 01:39 AM
corvette184's Avatar
corvette184
Default Re: IT'S HERE...... (SleepieAce)
:thumbs: :thumbs: :thumbs: :thumbs: :thumbs: i am finished with mine.....hhhmmmm what is next???? :eek:
Old Dec 21, 2003 | 03:10 PM
dads01dream
Default Re: IT'S HERE...... (corvette184)
"What's next"??? Hey I know..... hope on a plane and gimme a head installing mine next week! :smash: :D
To IT'S HERE......
