Question about Fuel Filter
Now, my question -- would the additional fuel load demanded by a supercharged application cause any oddities in the fuel filter? Premature wear mainly? I am trying to setup a maintenance schedule for my car and I'm thinking that the fuel filter will be done every 20K miles -- not that it's necessary, but just to keep the car running smooth.
Also, under what conditions would the PCM give P0300 (random misfires code)? Could it be related to fuel delivery and not just spark? The reason I ask is because P0300 came out of the blue in the last couple of weeks and since the fuel filter swap that code hasn't been fired again. It might be too early to tell though since it only happened once every 4 or 5 days.
Anyway, now I know what everyone meant when they said they went supercharged to maintain driveability! My Vette purrs like a kitten now and rides as smoothly as my Cadillac (well, until I start moving that is, but I like my car riding on rails)! :cheers:
If so, that could have caused some debris to get in there.
If you have a late 98-2002, you just changed your fuel pressure regulator also (it is inside the filter) and that probably has more to do with it running better than anything else.
And yes, misfires at idle are a/f related.
Some trivia:
A misfire just means that he PCM noticed the crank slow down between certain cylinder firing points (pretty easy to detect this at idle). Any type of really rough condition where the combustion is not on time and full will cause the crank to slow down (we are talking nanoseconds). The detection is actually a very complicated algorithm (especially on a high performance manual transmission car). The Feds mandated misfire detection around ’98 and it is actually one of the reason that some foreign cars were no longer sold in the US (Supra …).
[Modified by QuickSilver2002, 12:16 AM 12/28/2003]
[Modified by QuickSilver2002, 12:17 AM 12/28/2003]
Some trivia:
A misfire just means that he PCM noticed the crank slow down between certain cylinder firing points (pretty easy to detect this at idle). Any type of really rough condition where the combustion is not on time and full will cause the crank to slow down (we are talking nanoseconds). The detection is actually a very complicated algorithm (especially on a high performance manual transmission car). The Feds mandated misfire detection around Â’98 and it is actually one of the reason that some foreign cars were no longer sold in the US (Supra Â…).
Well, hopefully the misfires are gone with the new filter. Another fellow mentioned he's seen P0300 come up when there's a short in the injector wiring. Frankly I was not looking forward to hunting down a short anytime soon...
:cheers:
