Injector Size Question
Old Jan 1, 2004 | 10:29 AM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
Default Injector Size Question
Ok onto the next question. I am planning on running 5lbs of boost w/ this S/C will 30lb SVO injectors be enough? I am asking cause my buddy has a set that he said I could have if they were enough injector for what I want. Or will I need the 42lbs?
Old Jan 1, 2004 | 10:49 AM
VETZILLA's Avatar
VETZILLA
Default Re: Injector Size Question (C5kid)
the 42's will give you a good safety margin and they are pretty inexpensive. probably worth doing.
Old Jan 1, 2004 | 10:55 AM
SleepieAce's Avatar
SleepieAce
From: Kentucky basketball is life the rest is just details
Default Re: Injector Size Question (VETZILLA)
:iagree: At least go with 38...fuel starvation leads to detonation, which is the number one cause of FI engines going boom.
[Modified by SleepieAce, 10:55 AM 1/1/2004]
Old Jan 1, 2004 | 09:17 PM
z-u-later's Avatar
z-u-later
Default Re: Injector Size Question (SleepieAce)
:iagree:
Old Jan 1, 2004 | 11:13 PM
hogurt's Avatar
hogurt
Default Re: Injector Size Question (z-u-later)
Go with 38s at a minimum. No reason to take a risk for such an inexpensive part. . . :cheers:
Old Jan 2, 2004 | 06:38 AM
blu00rdstr's Avatar
blu00rdstr
Since you'll need tuning anyway, get larger than you need. This gives you a safety margin.
See www.ractronix.com for injector info. Stock system uses High-Z injectors, the biggest available right now are 57lb.
Note that ratings are at lower PSI than the C5 runs. The 57lb injectors flow 66lb @ 58psi, and my injectors measured at 44lb (They're gray, I suspect they're 38lb Bosch).
[Modified by blu00rdstr, 3:38 AM 1/2/2004]
To Injector Size Question
