Crank/Balancer bolt ?
Old Jan 1, 2004 | 08:37 PM
IM QUIKR's Avatar
IM QUIKR
Default Crank/Balancer bolt ?
If it is possible to loosen the crank bolt, how long is it and would you be able to remove it within the free space between the PS cylinder?
Old Jan 1, 2004 | 09:17 PM
z-u-later's Avatar
z-u-later
Default Re: Crank/Balancer bolt ? (drcoffee)
:lurk:
Old Jan 1, 2004 | 09:40 PM
JC-5's Avatar
JC-5
You would have to remove the power steering rack to get it out completely. Good luck
Old Jan 1, 2004 | 10:01 PM
QuickSilver2002's Avatar
QuickSilver2002
Default Re: Crank/Balancer bolt ? (JC-5)
There is a way to keep the PS rack connected to the PS pump and just push it up and out of the way. This only works if you do not need to remove the balancer. You need a brace or some type of helper to keep it pushed up higher on the Drivers side and you have just enough room to get at the bolt.
There is almost never a need to completely remove the steering rack from the car. In the worst case (like when you do a cam swap) you just push one end out the passenger side wheel well and angle the other end up.
Old Jan 1, 2004 | 11:16 PM
Sack Rat TT's Avatar
Sack Rat TT
Default Re: Crank/Balancer bolt ? (QuickSilver2002)
Just be sure to use a brand new bolt when you reinstall. Once streatched the bolt should not be used again. Bolt cost's about $7-8 I believe.
:smash: :smash:
To Crank/Balancer bolt ?
