Why 4 cyclinder mode?
Old Jan 19, 2004 | 09:28 AM
FASTENUF's Avatar
FASTENUF
Default Why 4 cyclinder mode?
Why do i run the MSD RPM switch in four cyclinder mode when it has an eight cyclinder mode?
Please don't get too technical, i would just like to know :steering:
Old Jan 19, 2004 | 10:30 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Why 4 cyclinder mode? (FASTENUF)
since our cars have coil packs instead of a distributor, there is a controller for each side of the motor. So when you tap into the tach wire, you are getting either the drivers side or passenger side which controls only 4 coil packs. This is why you have to put it in 4 cyl. mode.
Old Jan 19, 2004 | 12:19 PM
SpinMonster's Avatar
SpinMonster
Default Re: Why 4 cyclinder mode? (ICULUKN-C5)
What do vendors do when you order it for use with the ls1/6 motors?
Old Jan 19, 2004 | 01:05 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Why 4 cyclinder mode? (SpinMonster)
There is no need for conversion for use with the corvette.
To Why 4 cyclinder mode?
