staging winter modifications
Old Jan 25, 2004 | 03:31 PM
hogurt's Avatar
hogurt
Default staging winter modifications
The little general is cutting into my winter modification budget. . .so I am trying to figure out the best way to move forward with the mods.
I already have a Z06 cam and headers sittling in my garage. If I go ahead and have these installed, what other little things should I also add? Springs? Retainers? ARP studs? Rods?
It is likely I will add some forged internals so I can up the boost, next.
Old Jan 25, 2004 | 04:27 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: staging winter modifications (hogurt)
Although the Z06 cam is mild, it's still very streetable and will boost performance, the heads are a great choice IMO. I went with Patriot stage II LS-1 heads because I whimped out on upping the compression :bb
You should think about adding some stronger springs like Comp Cams 918 or 978 springs and definitely replace the pushrods with something better, just go to www.thunderracing.com and start shopping. :cheers:
[Modified by runamuk, 3:27 PM 1/25/2004]
