2nd thoughts on installing supercharger
Old Feb 17, 2004 | 01:07 AM
c5guy4life's Avatar
c5guy4life
Default 2nd thoughts on installing supercharger
i have the vortech supercharger kit sitting in my basement waiting to be installed but i am having 2nd thoughts. i have a 97 c5 with 43k miles on it. auto trans. what do you guys think? should i go ahead with the install? i am worried about future costs of possibly a broken trans or a blown rear end etc.... should i worry? what should i do?
Old Feb 17, 2004 | 01:22 AM
Red C5's Avatar
Red C5
Default Re: 2nd thoughts on installing supercharger (c5guy4life)
Stop worrying so much and do it. I'm not sure about your auto tranny, but the rear will be fine, unless you launch on slicks at the strip a few too many times.
Old Feb 17, 2004 | 07:32 AM
7LitreC5's Avatar
7LitreC5
I really think that you should go ahead with the project. I have not broken anything despite running autocrosses, laps on a road course, and 1/4 mile passes on drag radials.
Old Feb 17, 2004 | 07:49 AM
av8or3's Avatar
av8or3
Default Re: 2nd thoughts on installing supercharger (VortechC5)
Ithink you should put it on. I had simular concerns and installed mine anyway
and haven't regretted it. When you do,you make a car that normally is a
PITA to work on a little tougher,but that is the only real down side. Gas
milage is the same,power levels WAY up,it will be a different car and you will
like it. :yesnod:
Old Feb 17, 2004 | 12:15 PM
JakeL's Avatar
JakeL
I'll just parrot what the others have said. Unles you do a lot of launching on slicks (and it sounds like you don't) your rear diff will be fine. You might have some troubles with your transmission though - they don't seem to be as strong as the M6's. That said, I am about as far as it gets from knowledgable about automatic cars...
If you get a good LS1Edit tune, and are good about treating your engine well, the stock bottom should last for a long, long time.
...and if you decide you want to sell it, drop me a line ;)
-Jake
Old Feb 17, 2004 | 01:29 PM
COLORADO FRC's Avatar
COLORADO FRC
Default Re: 2nd thoughts on installing supercharger (JakeL)
I would go ahead and install it! You can always adjust the pulley size and control the amount of boost you make. I think I've heard that for each pound of boost you make, you get about 20 HP. I'll echo Jake, get a good tune and enjoy your car!
Old Feb 17, 2004 | 02:41 PM
night feeder's Avatar
night feeder
Default Re: 2nd thoughts on installing supercharger (Red C5)
:iagree:
Old Feb 17, 2004 | 02:48 PM
Terry Burger's Avatar
Terry Burger
If you can afford to repair the engine and/or trans when they blow, go for it, otherwise you might want to sell it.
Old Feb 17, 2004 | 03:01 PM
jonjon's Avatar
jonjon
Default Re: 2nd thoughts on installing supercharger (Terry Burger)
Just curious. What makes you think his engine and/or transmission will blow? Not a flame, just a question.
Old Feb 17, 2004 | 03:03 PM
HAYABUSA1's Avatar
HAYABUSA1
If I had a Vortech it wouldn't be in my basement... throw it on
Old Feb 17, 2004 | 03:11 PM
c5guy4life's Avatar
c5guy4life
Default Re: 2nd thoughts on installing supercharger (jonjon)
its alot of power to add to a stock 97 auto trans with 44k on it
Old Feb 17, 2004 | 03:44 PM
IM QUIKR's Avatar
IM QUIKR
Are you the only driver? If yes then just run it at your comfort level. If you plant your foot from start up to shut down or if you loan out the car to others, then Terry Burger is right on. If you drive conservatively and want some occational fun, I'm sure your car will outlast you. Relax and have fun. It's a sports car not a Geo Metro. The beauty of a Vortech or Procharger is that they only produce power when you get on it. Otherwise there is no boost to speak of.
Go for it! :thumbs:
Old Feb 17, 2004 | 05:30 PM
hogurt's Avatar
hogurt
Default Re: 2nd thoughts on installing supercharger (drcoffee)
I think you should NOT install the blower. . .just give it to me. :lol: :jester
Old Feb 17, 2004 | 09:01 PM
LS1 Bird's Avatar
LS1 Bird
Default Re: 2nd thoughts on installing supercharger (hogurt)
Four words >> PUT IT ON ALREADY!!! You'll be glad you did...
Mike M
Old Feb 18, 2004 | 12:17 AM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
C5guy4life,
It sounds like you haven't ridden in a supercharged C5 Vette! :troll Once you ride in one, you will have to do it! :reddevil
Under 3500 to 4000 RPM the car will drive like stock with no increased stress, as there is very little boost below that RPM-so no increased power/stress!
This will represent 98% of your driving.
Get a shift kit (higher system pressure for more solid shifts) and install the blower and thank us all! :smash:
Roy :blueangel:
Old Feb 19, 2004 | 06:21 PM
Terry Burger
He might drive it for years with no problems, or it might nuke the first time he nails it. It all comes down to tuning, and what condition his current parts are in. I'd agree with the previous post that his trans has some miles on it and is likely to give out. As for the engine, who knows. I'm just pointing out if he can't afford to break it, he shouldn't modify it. :)
Old Feb 19, 2004 | 06:48 PM
JakeL's Avatar
JakeL
I'm just pointing out if you can't afford to break it, you shouldn't modify it. :)
Good Advice.
A Lot of folks learned that one the hard way in the DSM club I used to be part of. If you need to save up a few thousand bucks as a starter towards a new trans or a new engine "just in case", then maybe it might be wise to let the kit sit in your basement for a few months longer.
I always keep a few thou in a 'backup' mod fund just in case something weird happens and I need to make an emergency repair or two, and that way it doesn't have to come out of "responsible" money accounts.
-Jake
To 2nd thoughts on installing supercharger
Old Feb 19, 2004 | 07:19 PM
Terry Burger
I read new for 2004 the 10% 401(k) early withdraw penalty is waived if you're pulling the money out to repair your supercharged C5... :)
Old Feb 19, 2004 | 07:57 PM
7LitreC5's Avatar
7LitreC5
That's pretty funny Terry! :lol:
Old Feb 19, 2004 | 08:18 PM
jonjon's Avatar
jonjon
Good Advice.
-Jake[/QUOTE]
Good advice guys :yesnod:
