Valve spring swap DONE!
Old Feb 24, 2004 | 07:44 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Valve spring swap DONE!
The replacement bolt for my rocker that I broke over the weekend arrived, so I finally finished the valve spring swap tonight. Once I got my "rhythm" down on techniques and how to position my hands to get the locks on the valve stems things really moved quickly.
I almost "brit a shick" when I tried cranking the car and nothing happened. Hmmm... Tried again a few more times and it finally cranked up. Whew! Guess it was just because all the fuel in the lines and fuel rail was gone. Then it started idling funny and the engine started smoking. Yikes! I shut the engine down. Then I remembered reading in one of jmX's how tos that this can happen from all the grease and finger prints and stuff that you spread over the engine. Cranked it back up and she idles like a kitten. I didn't have a chance to get her out on the road and check how it runs at higher RPMs because my BOV hasn't arrived back from Vortech (that's another story). It should be here tomorrow though so I can post back if the car runs differently now with the new springs.
In the mean time, here's a picture of my newly painted coil pack rails and valve covers:
Old Feb 24, 2004 | 08:16 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Default Re: Valve spring swap DONE! (diynoob)
That's great news............now stop breaking things at home and take it to the track :lol:
Old Feb 24, 2004 | 08:30 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Re: Valve spring swap DONE! (Z06GMAN)
:lol: Will do!
Old Feb 24, 2004 | 08:58 PM
vettewreck's Avatar
vettewreck
when are you gonna cross over to Magnacharger World???
Old Feb 24, 2004 | 09:49 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Re: Valve spring swap DONE! (vettewreck)
Probably sooner rather than later... but if my problems are related to engine issues they will follow me into the Mag world. So I want to try and solve as much as possible on my existing setup first.
Old Feb 25, 2004 | 09:56 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
what problems are you having with the engine or the ATI?
VR :cheers:
Old Feb 25, 2004 | 10:24 AM
SideStep's Avatar
SideStep
Default Re: Valve spring swap DONE! (vetterdstr)
BEST SIGNATURE EVER!!!
:yesnod: :yesnod: :yesnod:
:cheers:
Old Feb 25, 2004 | 10:26 AM
SideStep's Avatar
SideStep
... I can post back if the car runs differently now with the new springs.
Good news to hear! What fuel pump are you using????
:cheers:
Old Feb 25, 2004 | 10:29 AM
vetterdstr's Avatar
vetterdstr
Default Re: Valve spring swap DONE! (SideStep)
:cheers:
Thanks man!! :D
VR :cheers:
Old Feb 25, 2004 | 10:50 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
:cheers:
:iagree:
And, DIYNOOB, those valve covers look great. Did you powder coat them or use paint? :cheers:
Old Feb 25, 2004 | 11:04 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
VR :cheers:
I was having a few issues -- I don't know what the root cause is.
1) Loss of power at high RPMs (not sure how valve spring swap has affected this yet)
2) Not making very much power on headers/xpipe/exhaust/intake manifold/racetronix fuel pump (only 430rwhp w/ 6.5psi, expecting at least 480rwhp) -- this dyno occurred before I started losing power up top
3) Oil gets dirty fast and thick/black (could just be the Valvoline)
I should get my BOV back today so I can get the car on the road and see how it performs after the swap.
And I agree, your sig rocks :D
runamuk, thanks for the compliment. They are spray painted with engine enamel. It looks like I maybe should have used a strong bonding primer because the paint chips off quite easily. I might have to strip the covers down, resand, and then prime -- but I didn't see any engine primer at Pep Boys.
[Modified by diynoob, 10:05 AM 2/25/2004]
Old Feb 25, 2004 | 12:32 PM
vetterdstr's Avatar
vetterdstr
I hope the spring swap helps you out... as for the other problems I hope you get them fixed. Thanks on the kind words about the sig... :D
VR :cheers:
Old Feb 25, 2004 | 12:38 PM
IM QUIKR's Avatar
IM QUIKR
Have you done a compression check? Sure seems like piston rings and lots of blow by.
I hope not. :nonod:
Old Feb 25, 2004 | 01:09 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Re: Valve spring swap DONE! (drcoffee)
I hope not. :nonod:
Yep, that was QuickSilver's theory too. I haven't done a compression check yet because I wanted to get the car back together and actually get to drive her for a bit this weekend. Chances are I will take the car to my local Stealer to get the compression check done. When I was pushing air into the engine with my air compressor I could hear air leaking either out of the cylinder or out of the spark plug fitting, so either I have bad compression on all cylinders or the spark plug fitting I have doesn't fit 100% and would give a bad compression number anyway.
Old Feb 25, 2004 | 01:44 PM
vetterdstr's Avatar
vetterdstr
Just wondering here... why would you spend all that time changing the springs when you could have found out by doing a compression check if it was worth it or not??
VR :cheers:
Old Feb 25, 2004 | 02:28 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
I felt like the valve springs had to be done anyway -- all of my issues other than the loss of power at 5K RPM started since I had the blower installed. My thought was that swapping the springs could only help and not hurt, especially since the 5K RPM issue had just surfaced.
Most importantly though, I wanted to paint the valve covers and learn a little more about my LS1. :D
:steering:
Old Feb 25, 2004 | 02:29 PM
IM QUIKR's Avatar
IM QUIKR
For a few bucks you can buy a compression gauge and test for yourself. It's nice to have new springs but if the engine needs a tear down why bother? I believe the air compressor air leak is because the fitting is not air tight. Mine did it as well. I would not use that as a sign.
To Valve spring swap DONE!
Old Feb 25, 2004 | 02:30 PM
IM QUIKR's Avatar
IM QUIKR
:steering:
Ah ha! the truth be known :lol:
Old Feb 25, 2004 | 05:58 PM
Terry Burger's Avatar
Terry Burger
What tool/method did you use to compress the springs? If your little air compressor fitting has an ORing around it, it shouldn't be leaking from the spark plug hole. It's better to buy a leak down test and do it at home, save yourself $200 and know its done right. :)
Old Feb 25, 2004 | 07:18 PM
vetterdstr's Avatar
vetterdstr
If springs were the problem I hope it is now fixed. If you have to replace your engine, you wasted the install time and money. But I understand why you did it. :yesnod:
VR :cheers:
