BOV Connections
Old Feb 26, 2004 | 06:29 PM
brianw21's Avatar
brianw21
Default BOV Connections
In the instructions for the SIC from A&A it has you mount the BOV, but never describes connecting it. I think they are connected to the Vacum line aren't they? Any specific place?
Also where is the best place to connect a boost guage for accurate readings? Same place?
Old Feb 26, 2004 | 07:49 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: BOV Connections (brianw21)
You should have got a black manifold with 3 holes in it that hooks up inline with the vac line from the brake booster. That manifold has brass fittings that will hookup to the BOV, Gauge and you can also T off that to run the Boost a Pump.
VR :cheers:
Old Feb 29, 2004 | 09:42 PM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
I actually send the kit with the BOV mounted and the Vacuum line already attached. A lot of the kit is already assembled for you. The bracket and most of the tubing is already put together for you.It's easier for the DIY er when it's sent like this.
To BOV Connections
