Does LPE Use Internal Or External Wastegates ?
If its a Blitz unit IM me and I can walk you through making sure the unit is set up correctly for actuator style waste gates.
Mark,
Yours are internal as you can see them mounted on tour turbos from past pics. you posted.
Any word yet on where you stand?
:cheers:
:cheers:
With the controller off, she never exceeds more than 8.6 PSI. But I'm protected anyway with it on as I have a 11.5 PSI protection setting on the HKS EVC. Its just that even on low boost setting, it sometimes climbs to high boost. It sounds like something simple. I just hope I can figure it out - don't want to have to to shell out more $$$ for something simple.
Mark,
:cheers:
:cheers:
[Modified by MARK's_C5TT, 10:19 PM 3/3/2004]
Mark,
:cheers:
You mean regarding the Controller issue? BTW, real nice under-the-hood setup you got there!!!
:cheers:
I meant on your turbos do they need to be rebuilt and did you find out why you were having the blow by oil issues? :confused:
Thanks BTY on the :thumbs: for my motor. :D
:cheers:
Mark,
:cheers:
Mark,
:cheers:
:cheers:
Mark,
:cheers:
