Fuel pressure
Old Mar 4, 2004 | 09:10 PM
denscor's Avatar
denscor
Default Fuel pressure
I just put my boost and fuel pressure gauges in my car the fuel pressure only goes to 50lb at idle and stays there.The car has a LPE cam and heads with 50lbs injectors,are the injectors causing the pressure to be low?or did I get a bad gauge?Is the pump overloaded with the injectors? :confused:
Old Mar 4, 2004 | 09:24 PM
QuickSilver2002's Avatar
QuickSilver2002
Default Re: Fuel pressure (denscor)
What year is the car? Do you have a vacuum refrenced regulator on the rail?
ICULUKN-C5's Avatar
ICULUKN-C5
did you upgrade your fuel pump??? If not.. the 50# are too big for a stock fuel pump. When was the last time you replaced your fuel filter? How many miles are on the car??
Old Mar 4, 2004 | 09:27 PM
denscor's Avatar
denscor
Default Re: Fuel pressure (ICULUKN-C5)
The car is a 2001 with 6300 miles on it .The fuel pump is stock.
Old Mar 4, 2004 | 09:29 PM
ICULUKN-C5's Avatar
ICULUKN-C5
that must be one hell of a cam to require 50# injectors... upgrade your fuel pump... you should see 60-62 psi.
Old Mar 4, 2004 | 09:32 PM
denscor's Avatar
denscor
thanks, that is what I thought when I bought the cam from LPE but Ed Wright told me to get holley 50lb injectors because that is what he tunes for
Old Mar 4, 2004 | 10:23 PM
ICULUKN-C5's Avatar
ICULUKN-C5
I have a pretty large cam.... and I have 36# injectors... I dont know of what non-turbo application that would need that big of an injector...
To Fuel pressure
