NXL Kit and issues
Old Mar 8, 2004 | 04:57 PM
Cobra Skinner's Avatar
Cobra Skinner
Default NXL Kit and issues
Have the problems with the lag that occurs at the beginning of spraying with this kit been worked out? Also I was wondering whats so great about this NXL kit over the typical NX kit.... what are the benefits essentially? Also what comes with the kit, it says some type of harness and stuff? does this mean I don't need a wide open throttle switch and RPM activated window switch cause it comes with the kit?
Old Mar 8, 2004 | 09:46 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: NXL Kit and issues (Cobra Skinner)
I have the kit, and run the 180 jets with 36# injectors, on a stock fuel system... and have no hesitation. Maybe the hesitation is the air that is in the line, since the kit does not come with a purge.
Old Mar 8, 2004 | 10:35 PM
Cobra Skinner
Default Re: NXL Kit and issues (ICULUKN-C5)
will i have to switch over to bigger injectors? what does the kit exactly come with? does it come with the wide open throttle switch or maybe even the sensor and the rpm activated window switch?
Old Mar 8, 2004 | 10:36 PM
Cobra Skinner
also did you have to do any tuning for it?
Old Mar 9, 2004 | 03:57 AM
ICULUKN-C5's Avatar
ICULUKN-C5
You will not have to go to bigger injectors because this is a wet kit. You will want to retard some timing, and change your plugs from platunum to copper. NGK TR6's will do the trick. The kit comes with everything you will need to run. It does not come with a window switch. No ones kit does. Please let me know if you need any help.
Old Mar 9, 2004 | 08:47 AM
Cobra Skinner
Does it come with an electronic throttle position sesnor then instead of those cheap switchs that don't tend to work half the time?
Old Mar 9, 2004 | 09:31 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
I would get a mechanical ZZZThrottle switch....I believe they are better.
Old Mar 9, 2004 | 10:13 AM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: NXL Kit and issues (mikes99corvette)
mike you better pill up on that nxl to 180 shot before i hit town.......... :D
Old Mar 9, 2004 | 11:54 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: NXL Kit and issues (MC TORCH RED)
It does not come with a Throttle Positioning sensor. Usw the WOT switch that comes with the kit.
Old Mar 10, 2004 | 10:34 AM
redbob's Avatar
redbob
The issue is a loss of fuel pressure at launch. Some say to varying degrees but mine was a drop from 60psi to 30 psi. NX says that the kit emptys the fuel rails momentarly and that they are making an acumulator for it that will fix the problem. They have said this sense October when they first learned of the problem and continue to say next month every month. This is typical of NX. I took mine off and went back to my NX wet kit even though NX assured me that running a 180 shot of nitrous was ok with a lean spike that was off the chart on the dyno. :mad :mad :mad
Old Mar 10, 2004 | 10:46 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: NXL Kit and issues (redbob)
It is true that NX is making an accumulator. This is supposed to be out in 2 weeks. I personally have not had any issues with dropping fuel pressure.
Old Mar 10, 2004 | 12:31 PM
Cobra Skinner
How much is that going to cost? that should be included with there kit especially if the kit is faulty to begin with.
Old Mar 10, 2004 | 12:49 PM
ICULUKN-C5's Avatar
ICULUKN-C5
havent heard about extra cost... lets see if they even release it.
Old Mar 11, 2004 | 03:48 PM
redbob's Avatar
redbob
NX says the accumulators will be included with all future NXL kits they sell once they get them manufactured. Any one who already has this defective kit will be allowed to purchase one at a bargain price. :rolleyes: :rolleyes:
Old Mar 11, 2004 | 04:25 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Several people over at LS1Tech ran into this exact same problem as you've mentioned above. When I spoke to NX about it, they said the acumulator won't be available to the hand of end-users for another couple months. :crazy: :crazy: :crazy:
Old Mar 11, 2004 | 09:41 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: NXL Kit and issues (Tuan Le)
I would suggest that anyone that is having fuel supply issues to the nxl rails, check your fuel filters first. I picked up 2 psi (from 58-60) on a stock fuel pump just by changing the filter. These filters are only good for about 10k miles.
Old Mar 12, 2004 | 06:24 AM
rwj383's Avatar
rwj383
has anyone tried upgrading their stock fuel system with a Racetronix intank upgrade kit?? I'm told this upgrade will greatly reduce the initial fuel pressure loss when nitrous first engaged.
To NXL Kit and issues
