4L60E Transmission
Old Apr 11, 2004 | 11:24 AM
js23881's Avatar
js23881
Default 4L60E Transmission
Just installed Andy's Procharger set up. C5 4L60E is slipping at certain power ranges. Any advice as to can I rebuild existing 4L60E or do I need a new "hardned" one built. If I need new any suggestions as to who and how much. I have 433 rwhp with 450 r torque.
Old Apr 11, 2004 | 01:14 PM
b98's Avatar
b98
Default Re: 4L60E Transmission (js23881)
I went with the FLP-level 4, works great . I would change the converter at the same time . Andy said the 2800 is just right.
Old Apr 11, 2004 | 02:20 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: 4L60E Transmission (b98)
www.flp2win.com, mine is supposed to ship Monday (tomorrow)
Old Apr 11, 2004 | 04:32 PM
c5guy4life's Avatar
c5guy4life
Default Re: 4L60E Transmission (runamuk)
but do they make the ride uncomfortable?
Old Apr 11, 2004 | 05:26 PM
b98's Avatar
b98
Default Re: 4L60E Transmission (c5guy4life)
Old Apr 11, 2004 | 07:47 PM
c5guy4life's Avatar
c5guy4life
does the trans shift harder to where it is uncomfortable for daily driving?
Old Apr 11, 2004 | 10:34 PM
esram's Avatar
esram
No you will be just fine, if you feel it is to firm you can adjust the line pressure with predator and or other programing.
Old Apr 12, 2004 | 09:36 AM
js23881's Avatar
js23881
Not that I'm the dullest tool in the shed but......what is an FLP-level 4?? Is that a kit I can add to existing tranny or a whole new transmission...also where can I get it. Like the converter idea too.
Old Apr 12, 2004 | 11:15 AM
VETZILLA's Avatar
VETZILLA
The FLP trans is IMO the best A4 out there for high power C5's. It is not a kit but a whole new built trans. Look on the left side bar and you will see Finish Line Performance's banner click on it and give them a call, ask for Mitch or Chuck they will hook you up, they are great to deal with and stand behind their product. They will also spec a T.C for your application.
Good luck and tell the guys over there Vetzilla says hi.
Mike
Old Apr 12, 2004 | 02:15 PM
powderski13's Avatar
powderski13
The FLP Level IV rocks. I had Andy install one when he did my superchager install. Also went with a Vigilante 2800 TC and 3.42 gears at the same time
Old Apr 12, 2004 | 02:42 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The link to FLPs website is: www.flp2win.com
Old Apr 12, 2004 | 05:21 PM
blu00rdstr's Avatar
blu00rdstr
Actually my FLP L5 shifts smoother than stock. Partially because of a vacuum mod where vacuum triggers a softer shift. You have to add a vacuum line to the transmission.
Old Apr 12, 2004 | 07:55 PM
blown in n.c.'s Avatar
blown in n.c.
Default Re: 4L60E Transmission (blu00rdstr)
Give Mike or Skip at More Performance here in Charlotte a call. They have a rock solid A4 upgrade for our cars.
Old Apr 13, 2004 | 12:48 AM
George8211's Avatar
George8211
Default Re: 4L60E Transmission (blown in n.c.)
Hey Blu..... Level 5 Why a level 5? You are the first level 5 I have seen on the board.
By the way.... Your coolant over flow tank sure is full.
Old Apr 13, 2004 | 11:26 AM
SilverStar's Avatar
SilverStar
It shifts smoothly under light acceleration, but with your foot deep into the pedal it will snap your head back some. I love it but my wife hates it.
Old Apr 13, 2004 | 12:12 PM
Hool97's Avatar
Hool97
Rebuid it with the FLP they are a solid company, though sometimes backlogged. Raptor trannys and others are out there. The TC needs to be built for the application too, my SY3500 is slipping above 440Hp/400tq/5400rpm. So I am going to go with a different unit.
PS I think Andy has a FLP L4 sitting in his bay.
Old Apr 13, 2004 | 02:21 PM
blu00rdstr's Avatar
blu00rdstr
Default Re: 4L60E Transmission (George8211)
I went level 5 for the same reason Spinal Tap went to level 11.
The torque estimates on my motor vary widely, and I wanted to fix things only once. Plus it was only $700 more.
To 4L60E Transmission
Old Apr 13, 2004 | 02:48 PM
George8211's Avatar
George8211
Good answer
I agree
Old Apr 13, 2004 | 04:40 PM
VETZILLA's Avatar
VETZILLA
Yeah, I can't say enough about FLP, I would of gladly paid the extra $700.00 for the level V if it was available at the time. Not that my Level IV won't easily handle what I can throw at it but I'm sure with my addiction to power I will someday need to step up again.
Old Apr 15, 2004 | 12:08 PM
FLP's Avatar
FLP
Default Re: 4L60E Transmission (esram)
Our Level 4 and Level 5 transmissions are vacuum modulated and the line pressure is no longer controlled via the pcm. By no means is our transmission uncomfortable for daily driving. Feel free to check out the transmission section of our web page.
www.flp2win.com/content/transmission/masterprice.htm
Thanks,
Mitch
Mitch@flp2win.com
630-820-9294 ext. 222
630-820-9259 fax http://www.flp2win.com http://www.flpdyno.com
