I am trying to get all my ducks in a row before the blower install next weekend. I was going to install a check valve to replace the PCV. Several forum members suggested the PCV was too weak for a FI application. I purchased the below check valve from McMaster Carr but the vacuum resistance seems to high to open the valve in the direction you want the vacuum to draw.
Any one using this??? Opinions???
- Maximum Pressure: 1000 psi
- Cracking Pressure: 0.3 psi
