First dyno numbers out on blown all-bore
Bill at Xtreme said they did a couple initial tuning pulls up to 4500 rpm on the dyno. Got 574 rwtq and 500 hp with 10psi boost. Still have about 2000 rpm left to redline. Bill has to swap out the clutch for a dual disk and do Andy's fix on the blower intake cause it was collapsing. Hope to get updates later today or tomorrow but seems like it'll be a beast
Re: First dyno numbers out on blown all-bore (Inelpaso)
... 600hp at 5600RPM... and then we let the smoke out of the clutch. DOH! Hate it when that happens. Exedy twin disk going in as we speak ... then back on the rollers
Re: First dyno numbers out on blown all-bore (SleepieAce)
Dyno graph below shows the last dyno run. The very next dyno run the clutch would not hold at all from the very start. The little blip at the end shows slight clutch slip. No KR reported at 16 degrees.
We had to fight with the Exedy twin disk a little... but its now in and the car is going to back together. Hope to have some more numbers tomorrow...
Bill
Bill
Re: First dyno numbers out on blown all-bore (slong)
Inelpaso,
Do you ever make it out to the track (off Montana)? Just moved to El Paso a few months ago. Anyway, if you do I'll look out for your car. Congratulations, nice dyno numbers.
Respectfully,
Velocity Driven
Respectfully,
Velocity Driven
Re: First dyno numbers out on blown all-bore (Velocity Driven)
There is Thunder Alley off Montana and Desert Demons off Pellicano at West Texas Airfield. TA is more professional and expensive and DD is more popular with the locals. Either if fun. See ya there.
to you and Extreme! Those are great numbers, but the scariest thing is that there's probably more to be gotten in there, and I'm sure that Bill will get it out for you! Drive Safely!
Thats great! I was at Desert Demons race track this past Friday (been to Thunder Alley as well). I hope to meet you at either one. In the meantime if you see an '04 C/E C5.......thats probably me.
Again, congratulations on some great dyno numbers.
Respectfully,
Velocity Driven
