LPE Walbro pump
Old Jan 24, 2005 | 05:09 PM
xlr8shn's Avatar
xlr8shn
Originally Posted by Racetronix
That all depends on the BSFC of the motor, if the car has a '97 style return system, the health of the factory pump and which version of the factory pump you have.
So 1997 C5's are the one models with the fuel pressure regulator at the rail?
I am going to purchase and install the Racetronix pump and wiring in my '99 C5 in prep for an A&A P1SC kit.
So, I need to order and install the MSD Fuel Pump Booster also...?
Old Jan 24, 2005 | 06:24 PM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
Originally Posted by QuickSilver2002
I'm running a racetronix pump + BAP + 97 rail and it is supporting 670RWHP without any problems at all. FP is 68+ psi at 9psi of boost. I would guess it will support well over 700rwhp.
Before the 97 rail I was having pressure drops at 500rwhp.
I personally think people would be better off trying the fuel rail mounted regulator before they try a new pump.
Based on MY system I would tend to disagree with the previous power statement.
I have the '97 rail, BAP, and Racetronics pump also (3rd pump of theirs in 3 months). On my system 9 PSI (~4500RPM on COLD fuel) is the max, then the pressure drops like a rock. If I've been tooling around under light throttle for a while 4 PSI is max!!! I understand that there IS a physical difference in the pumps between the two and my next move is to try the LPE and see if there's an operating difference because things obviously aren't working properly right now.
FYI, I have been in contact with Racetronics to no avail and they also told me that Walbro doesn't support their product!
FWIW, a supporting dealer of Racetronics did all the installs and replacements so they were definitely installed per mfg recommendations.
Old Jan 24, 2005 | 06:35 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Sorry to hear about that pump going out again Paul, you are not the first one that I heard of having a problem with the Racetronix Pump. Maybe they are having problems with that supplier too as they did with the rail conversion they were attempting.
The LPE pump is superior in quality, it supplied my hp without a BAP..fuel pressure never went below 54psi on a hi boost run. Now I have a BAP and will use OPTICZ's adapter/regulator to tie it all together.
Old Jan 24, 2005 | 11:11 PM
cnationshb's Avatar
cnationshb
does anyone have a fuel system that works on a late 03 car?
a proven system that works all the time every time?
admittedly i dont have fi or any reason to need a hi perf supporting fuel system right now, just plotting out a high horsepower course. finding that there seems to be lots of differing opinions on what system works and also lots of combos that were created to support high hp, but ended up having limitations.
i guess what im interested in seeing is someone able to say if you have a late 03 vette and want 500 hp do this... 500-750 do this...above 750 do this...
or whatever the hp groups there may be.
or are there just too many other variables to have a cut and dried list of options?
Old Jan 25, 2005 | 02:38 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
I run the LPE pump as well. It is a true plug and play. I have added the relay and draw my power directly from the alternator.
While both these pump are made by Walboro, and are both 255s, there are a few distinct differences.
The Racetronics pump is originally intended for a Chrysler hipo truck package, and therefore the aspirator is 100 degrees off the stock and LPE position. The polarity is also reversed on the RT pump and it has a check valve in it as well....
Old Jan 25, 2005 | 07:04 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Coming up I will be removing the Racetronics pump and going to the LPE unit as well as installing optic's fuel setup. Hopefully it will take car of not having to do the 97 rail conversion that my car has been needing.
VR
Old Jan 25, 2005 | 07:28 AM
Racetronix's Avatar
Racetronix
Supporting Vendor
VR
Try Optic's fuel rail setup first if it provides a return.
Changing pumps will not net you any gains assuming your pump is healthy.
Old Jan 25, 2005 | 09:59 AM
Ed@Lingenfelter's Avatar
Ed@Lingenfelter
Originally Posted by Allgonoshow
Ahaaa! Since I got LPE and Racetronix in the same post here....What do you guys think the stock pumps will support with a custom 10g wire harness from the bat or alt with and without a BAP?? I'm curious if the little time it takes to run some new wire and relays is worth it without buying a new bump or BAP.
[Modified by Allgonoshow, 9:20 AM 4/26/2004]
I'm not sure what you're trying to accomplish by just running larger wire to the pump? Are you wanting to send more voltage to the pump for more output? kind of a homemade BAP? To be honest, we've never tried this,we simply go the the BAP and wire it up to a manifold press switch, so that it gets full voltage boost as soon as we see +2psi manifold pressure. This works very well, and for higher HP applications, our intank pump is all that's needed.
cnationshb - I can answer your questions as for what needs to be done on the late-'03 & up cars at certain power levels, but I'm sure you won't like the answer
Ed
Old Jan 25, 2005 | 10:56 AM
Shinobi'sZ's Avatar
Shinobi'sZ
The plastic parts are redundant.
The LPE version has NONE of the upgrades and benefits that the Racetronix system has to offer other than the pump itself.
The wire is hidden and runs up the underside of the car with the brake lines in the drive shaft tunnel. It is VERY simple to install.
Call Andy @ A&A and he can better explain.
I don't remember this being a Racetronix comparison to LPE thread. If there was another Racetronix thread it would avoid using the LPE Pump thread to "Pimp" the Racetronix product. Its obvious you are not going to come on here and talk about all the pump failures, that can be catostrophic on a FI application. I know I will never use your Racetronix again, unless of course you come up with a reliable in tank that puts out over 300lph. I am currently using the LPE pump, if I change it will be to the Bosch in tank pump.
Old Jan 25, 2005 | 10:59 AM
SmoothFRC's Avatar
SmoothFRC
I thought the LPE and Racetronixs used the exact same walboro pump?
I have also had a faulty pump from racetronixs, and i think my new one is going also - (dropping pressure at idle after only an hour of driving on a full tank)
Old Jan 25, 2005 | 01:23 PM
VETZILLA's Avatar
VETZILLA
Originally Posted by Ed@Lingenfelter
Our in tank fuel pumps can support up to around 600RWHP by themselves, after that a BAP is all that's needed to support mich hihger levels. The nice thing about them is the easy installation.
Ed
850rwhp plus shouldn't be any problem at all with a 97 boost referenced rail, -8 supply, -6 return, hotwire from alt and a KB BAP.
The LPE pump has been flawless thus far.
Old Jan 25, 2005 | 01:31 PM
Sack Rat TT's Avatar
Sack Rat TT
Ed[/QUOTE]
I think I know where Ed is going here. Replacing the entire fuel tanks and delivery lines and using fuel rail regulator as on the early 97-98 cars. A few of the early 03 cars had the older style tanks with the pump located at the bottom. All they need is the fuel lines, fuel rail/regulator, Walbro pump and BAP. Good luck.
Old Jan 25, 2005 | 01:53 PM
21STCENTURYMUSCLECAR's Avatar
Premium Supporting Vendor
Well said and supposedly a definite no no.
I believe its call HIJACKING a thread.
Old Jan 25, 2005 | 01:54 PM
GR8-LIFE's Avatar
GR8-LIFE
In all fairness, I had a Walbro and that failed after 2.5 years.
Old Jan 25, 2005 | 02:08 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
Originally Posted by denscor
Is any one using this? I need a fuel pump but I'm confused on the right one to buy.I like the racetronix but I don't like the wire running up all the way up the car .What I understand from LPE that it already comes in the canister
Old Jan 25, 2005 | 02:22 PM
Paul @ Thunder's Avatar
Paul @ Thunder
We have a Racetronix prototype '04 system in a 427 Corvette right now and it's working great. The car is making 525rwhp NA and the pressure is rock solid. We don't have any kind of wiring harness or voltage booster on it, just the in tank pump. With the way the pressure is I would say it's good for quite a bit more power and the booster harness will help it even more.
As far as the other situation goes we have installed ton of the C5 and f-body pumps here in the shop and have never had a single failure. Now I'm not saying one can't fail for one reason or another but I don't think it's a wide spread issue.
Old Jan 25, 2005 | 02:47 PM
Shinobi'sZ's Avatar
Shinobi'sZ
How many of these cars were FI??? The FI requirements of a fuel system are far greater than for under 550rwhp NA. I have seen the stock pump support that.
Something else to consider LPE warranties their kits for 2/24 year/mile, which includes their pumps.
Maybe other pump makers could offer their pump with a 2/24 year/mile warranty. This would probably eliminate the discussion.
To LPE Walbro pump
Old Jan 25, 2005 | 02:52 PM
Paul @ Thunder
We've done quite a few FI cars, both C5 and F-body.
FYI: The stock pump would not support the 427 in this '03 Z06. Tried it!!!
Paul
Old Jan 25, 2005 | 02:56 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Paul
The fact that it was an 03 explains it. Do you guys offer a warranty of any sort on the whole package?
Old Jan 25, 2005 | 03:16 PM
Paul @ Thunder
Why does the fact that it's an '03 explain it? Same fuel system in the late '03 and the '04s.
It a racetronix product so any warranty would go through them but if I install a pump here in the shop then I will warranty it.
Paul
