Win a Cam
Old May 9, 2004 | 11:50 PM
nfshotrod's Avatar
nfshotrod
Default Win a Cam
I am doing to do a top speed run next week at a local airport. The airstrip is 6100 feet long, I am giving away a LPE Gt2-3 Blower cam to the person who can guess the top speed. The camshaft has 1000 miles on It. The car has a 3.73:1 gear ratio. 382c.i. motor, Twin Turbo.
Old May 10, 2004 | 12:20 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Win a Cam (nfshotrod)
192 mph this is given that you are using a 345/30/18 and a 6800 rev limiter on a MN6 transmission. You should be able to get past the 1320 in the 130's.
[Modified by ICULUKN-C5, 10:22 PM 5/9/2004]
Old May 10, 2004 | 12:24 AM
BlackMagicC5's Avatar
BlackMagicC5
Default Re: Win a Cam (ICULUKN-C5)
190 mph
[Modified by KillerVette99, 12:29 AM 5/10/2004]
Old May 10, 2004 | 12:36 AM
BlackMagicC5
Default Re: Win a Cam (KillerVette99)
[Modified by KillerVette99, 12:36 AM 5/10/2004]
4N EATER's Avatar
4N EATER
194.....good luck
Old May 10, 2004 | 12:45 AM
WS6speeDemon's Avatar
WS6speeDemon
Default Re: Win a Cam (4N EATER)
195.... i think you might get faster than that but 195 is my FINAL answer...
[Modified by 97Vitesse, 5:56 AM 5/10/2004]
Old May 10, 2004 | 01:46 AM
Red C5's Avatar
Red C5
168mph
Old May 10, 2004 | 02:42 AM
ownedya's Avatar
ownedya
200
Old May 10, 2004 | 02:45 AM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
174 MPH,
Good luck,Rubber side down,
Roy
Edit: Sounds like you're doing the equivalent of a standing start mile, 5280 ft + shut down= approx 6100 ft.
If you could get them to let you come careening :shocked: in off the highway so that you would hit the starting line at 70 to 80, and you are lowered, some kind of belly pan, and duct taped, maybe that would work for a little higher terminal speed!
But, I think I'll stick with my original 174 MPH prediction.
Check with Jbsblownc5 for some of his magic elixor-might be needed on that last quarter mile!
Best of luck, and I hope my estimate is 20 MPH low!
Roy
[Modified by 7.0sc SuperVette, 9:57 PM 5/11/2004]
Old May 10, 2004 | 07:36 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
193 MPH
Old May 10, 2004 | 08:31 AM
SideStep's Avatar
SideStep
205!!!!
I want (need) that CAM!!!!
Old May 10, 2004 | 08:48 AM
Thingobump's Avatar
Thingobump
188
Old May 10, 2004 | 09:21 AM
Phil97SVT's Avatar
Phil97SVT
Default Re: Win a Cam (Thingobump)
191
Old May 10, 2004 | 09:30 AM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Default Re: Win a Cam (Phil97SVT)
196
Old May 10, 2004 | 09:54 AM
'97 C5's Avatar
'97 C5
I'm guessing 202 mph. good luck!
Old May 10, 2004 | 10:12 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: Win a Cam ('97 C5)
176
Old May 10, 2004 | 10:57 AM
Rollin Black's Avatar
Rollin Black
189 MPH
Good luck
To Win a Cam
Old May 10, 2004 | 11:04 AM
vettekid00's Avatar
vettekid00
203 mph
Old May 10, 2004 | 11:26 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Default Re: Win a Cam (vettekid00)
199
Old May 10, 2004 | 12:02 PM
Drako's Avatar
Drako
Default Re: Win a Cam (Ragtop_Rob)
184 mph
