Set-up for big cubes and nitrous
Old May 17, 2004 | 01:59 PM
supercoupe01's Avatar
supercoupe01
Default Set-up for big cubes and nitrous
How much performance n/a do you sacrifice when setting a big cube motor up for n/a and nitrous instead of just n/a? What changes have to be made to the (heads/cam, etc.)? What nitrous system would be best for having control over when the spray will kick in?
Old May 17, 2004 | 11:48 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Default Re: Set-up for big cubes and nitrous (supercoupe01)
Man that's a loaded question, there are so many variables. What comp. ratio were you planning on running NA compared to na/n20, thats a starting point. Also, same question applies to cam. What bore/stroke combo, c.i.d. were you shoting for. And it goes on. I keep a running log on who's running what -vs- HP for comparisons. You can get the same HP out of a NA engine compared to a n2o engine of the same cid by using different cams, comp ratio, ported heads etc. Hope this helps a little.
