Re: Dyno results for user: "addicted" (CHRIS NJ C5)
Thaks to Rich for hosting my dyno sheet. The car is awesome...pulls harder than I expected. Need to fond out how to hook up at the track. I'm still spinning with ET Streets. Tried several different psi, and 13 psi seemed best last night. :flag
512RWHP and 433RWT. The A/F ratio is 12.6 at 6200 rpm. I'm not sure why this is lean??? I thought 12.6 for A/F ratio is in the acceptable range. The lowest it drops is 12. Any comments??
The higher the # the leaner you are. Best to be 11.4 to 11.7 for a safe tune.
I agree...it appears that he dropped that hammer much later than the start of the graph. Everyone has a different opinion on optimum AF ratio. My NA car is running 12.1 on a dyno, which is around .5 richer than the street. Some tuners have you sign a waiver if they tune above 13.0. My .02
by the look of the graph, id say he wasnt on it till ~4.2krpm as cars simply dont run 14.7a/f ratio at WOT, good numbers tho
