Switched Power??
Old May 31, 2004 | 10:30 PM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default Switched Power??
Where are you guys getting your switched power (of and on with the key) for the nitrous buttons and such? I had tapped one of the wires for the radio, and that worked, but now the radio and the buttons don't work?
I originally wanted to go off the cig. lighters, but they are always on, thanks. Thought I was almost done with this isntall
Old May 31, 2004 | 10:53 PM
HalfMoon's Avatar
HalfMoon
Default Re: Switched Power?? (TexCorvette)
As long as you don't have a 2004 (profile says 1998), used the steps in the begining of this tech tip...
https://www.corvetteforum.com/techti...=165&TopicID=1
Old May 31, 2004 | 11:02 PM
TexCorvette
Default Re: Switched Power?? (Tony_C5_04)
Now my radio and front cigarette lighter don't work, but the 2'nd cig lighter in the armrest does have power though!? Can't find any blown fuses?? Anyone know where/what I should look at.
I've separated anything from drawing power from those sources? I check all the fuses near the battery and most in the passenger compartment. I don’t have the little plastic cover for the one in the passenger foot well, so I don’t know what is what there?
[Modified by TexCorvette, 11:08 PM 5/31/2004]
Old May 31, 2004 | 11:09 PM
TexCorvette
Also, I wanted power near the switch panel, is it ok to tap off one of the AC unit power wires?
Old Jun 1, 2004 | 12:00 AM
HalfMoon's Avatar
HalfMoon
I wouldn't recommend tapping into anything. Thatr only seems to cause problems.
Old Jun 1, 2004 | 12:11 AM
TexCorvette
Guess your right, cause now the blower doesn't work, the instructions you posted have me taping power to the BCM, I guess that's ok? I'll just do it from here like I should have, and hope my other issues are fuses.
To Switched Power??
