MINI TUBBS
Old Jun 13, 2004 | 09:44 AM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Default MINI TUBBS
I just got the complete kit from LPE and I was looking at getting my body shop to do the tubbing, My car is apart getting the Targa kit installed. I need as much info and Pictures as I can to help my body guy out. The install info at LPE is lacking IMHO. Also need info on the hardware install. Thanks for the help.
Old Jun 13, 2004 | 08:40 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Re: MINI TUBBS (Z06GMAN)
Just curious to those who have tubbed, is your traction that much better? Would you recommend it over just getting a better compound tire?
Sorry, I hope I am not hijacking.
Old Jun 13, 2004 | 11:06 PM
Icetech's Avatar
Icetech
Default Re: MINI TUBBS (diynoob)
DIY i have seen guys with minitubs running 345's and still losing traction like crazy.. every mm of width and compound helps
Old Jun 13, 2004 | 11:18 PM
FreddyG's Avatar
FreddyG
Default Re: MINI TUBBS (Icetech)
Rubber compounds, in my opinion, are much more important than width. That's why a car that runs in the fastest street car shootout (guys like Billy Glidden, Mike Moran, that run in Real Street Class etc.) run so fast on a 10.5" tire? It's because of the compound (suspension set-up doesn't hurt either), and they're putting out a WHOLE bunch more power than our cars do (that includes the 8.95 second LPE car too, Which is incredible considering the suspension that we have to work with)! Just my .02
Old Jun 13, 2004 | 11:23 PM
EatRice's Avatar
EatRice
Excellent write up except one item. Correct me if I a wrong but the Corvette is made of SMC not fiberglass. If that is the case then you are much better off using epoxy then polyester resin. Polyester resin will not form a bond to SMC and under stress will pop off. If the car is made of fiberglass then polyester or epoxy will work. One other thing mentioned is the mix ratio on the epoxy...not all are 1:1. Make sure when you purchase you find out which one you get.
Old Jun 14, 2004 | 02:50 AM
George8211's Avatar
George8211
Default Re: MINI TUBBS (EatRice)
Gary I posted it here for you... It's PDF format... It included needed tools, instructions, complete with pictures
[Modified by George8211, 2:55 PM 6/14/2004]
Old Jun 14, 2004 | 12:15 PM
FreddyG's Avatar
FreddyG
Default Re: MINI TUBBS (George8211)
Better compound = Better traction .... once you run out of great compound... then go more width with same compound.
Also... Many street drag racing classes are limited by tire size... I see 10.5 upper limit on most street classes... that is why you see so many 10.5 tires on the track.
with you George. The Fastest Street Car Shootout Real Street class is limited to a 10.5" tire. My point was, that if it can hook up an 800rwhp motor, with a 400hp shot on top of that (VERY violent, as far as traction goes), that it can hook up JUST ABOUT ANYTHING that we could throw at it.
Old Jun 14, 2004 | 01:40 PM
VETZILLA's Avatar
VETZILLA
Default Re: MINI TUBBS (LuvmyC5)
Gary
The mini-tub is very easy to install, just follow the directions. Also be sure to have the shock travel limiters installed that came with the kit. Livernois Motorsports installed mine in about 5 hours complete.
Oh yeah, I'm running the mini-tub and 345's Michelin Pilots on 12.5" wheels, I can spin the tires still at 70mph so unless you are going to run 18" rear wheels with 345/30/18 BFG Drag radials don't expect any significant improvement in traction.
If I had it to do over again I would of gone with 18" all the way around so I could run the DR's all the time, having gobs of power is one thing but unless you can stick it to the pavement what good is it. I can't even imagine trying to get traction with your new setup since it will probably be pushing 100-150 more rwhp than I am running.
Old Jun 14, 2004 | 02:51 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Thanks for the info, but I really need is someone that did the LPE kit and some detailed instructions and Pictures (not asking for much am I) Anyone know who did the LPE Kit that I can e-mail. I think my body shop guy can do it and since car is all apart including the back fenders panels it should be an easy process.
Thanks for the help
Gary
Old Jun 14, 2004 | 02:57 PM
George8211's Avatar
George8211
Old Jun 15, 2004 | 07:55 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I love mine....I did mine locally but here is a link to some pics that may help you visualize the install.
I am running 345/35/18s Bridgestone Expedia S-01 345/35ZR18 tires for the street....140 tread wear and do pretty good on the strip too...........but not as good as the 345/30/18 drs
http://www.hpracecraft.com/car_Steves-vette.html
Here is another write up.......I used all the forum info to do it!
http://www.thetechzone.com/articles/...ng/index.shtml
[Modified by ALLTHROTTLE&NOBOTTLE, 8:00 AM 6/15/2004]
Old Jun 15, 2004 | 08:10 AM
VETZILLA's Avatar
VETZILLA
Gary
If your body guy has questions have him call and ask for Jeff Davis at Livernois Motorsports #313.561.5500, he installed mine and did a great job.
Mike
Old Jun 15, 2004 | 09:08 AM
EatRice's Avatar
EatRice
Default Re: MINI TUBBS (VETZILLA)
What has to be done with the shocks when doing a mini tub?
Old Jun 15, 2004 | 12:47 PM
Operations's Avatar
Operations
Old Jun 15, 2004 | 01:50 PM
Cruise-In V Veteran
NCM Ambassador
Nothing..............F45 here and +74mm HRE 545s.
At full extention(lifting **** off the ground) the inner wheel barrel just touches the upper a-arm. No problem or shock limiters needed here........each car can be different though
Here is a pic
Old Jun 16, 2004 | 07:23 AM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Default Re: MINI TUBBS (ALLTHROTTLE&NOBOTTLE)
Thanks everyone, Took the LPE Mini Tub kit over to Mario yesterday. The car is coming along. No top makes a big difference. Anyway thanks for the help.
Old Jun 16, 2004 | 07:11 PM
Sack Rat TT's Avatar
Sack Rat TT
I believe the LPE kit still contains shock travel limiters installed with shocks off the car. They recommend going to 19 inch rears to gain added clearance between the inner wheel lip and the top of the upper control arm with wheels at full down travel. They also alter slightly the upper shock mounting geometry as well. All this addes up to peace of mind should the car get light or slightly airborne as it keeps the wheel off of the control arm.
To MINI TUBBS
Old Jun 18, 2004 | 10:31 PM
97C5ENVY's Avatar
97C5ENVY
Here's everything you need to know about mini tubbing....including shock travel limiters and wheel offsets.
http://forums.corvetteforum.com/zerothread?id=773334
Old Jun 18, 2004 | 10:46 PM
NJ99FRC's Avatar
NJ99FRC
From: If you can see the car behind you, your not going fast enough
we need pics of a no top car... you should know better!
Old Jun 19, 2004 | 12:24 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Default Re: MINI TUBBS (NJ99FRC)
Man you and your Pictures Well to tell the truth I forgot my camera when I went over. If I get over there before it's finished or BlackSun gets some(hey John you said you would) I will post them. Right now it looks like you will see completed Pictures. Seems like all this mod stuff involves a lot of waiting on stuff. I was waiting on my top, Mini Tubs, Interior and the HRE 541R's . I am still waiting on the wheels and interior. The bad thing about all of this as soon as my car is done at Mario's place it will be going over to FLP for the engine Mods, It's going to take 2 weeks over there but we all know that might be 4 weeks. Oh well there is always next summer to have fun.
