OOPS! I did it again......
Old Jun 14, 2004 | 10:45 PM
dads01dream's Avatar
dads01dream
Default OOPS! I did it again......
Whelp, you'd think I would have learned.
Back on Friday I spoke with Chris @ ECS to find out how my D1-SC install was coming along, unfortunately there were a few tidbits missing from Andy's kit that they needed to fab up. Hooo well.
Anyhow we got into a discussion about my WEAK 2.73's and one thing led to another and so now they're installing an SS3600 T/C with a new 3.42 diff.
Then, I call on Sat. for a progress report as I was hoping to pickup the car on Sunday. Chris noticed that the Vette was still running factory exhaust manifolds! THIS CAN'T BE!!! So, Chris delicately suggests that since the bottom of the car was pretty clear from doing the T/C install and running the wiring up for the Racetronix FP...... I quote "we could do a set of Kook's LT's for a real good price since we're already here, what do you think Mike?" Uhhh-huh.
Anyhow, the car should be ready in the next couple of days with the completed D1-SC kit, Racetronix installed, NGK TR6 plugs, check valve, 160* T-stat, 48lbs. injectors, SS3600 T/C & 3.42's, and now FINALLY (I hope) a set of 1-3/4" Kook's LT headers with Random Tech cat-pipe dumping into my existing Corsa Indy exhaust.
I'm going to wait till I "think" the car is finished before calling there again!! The spousal-unit is going to have me sleeping in the car if I keep this up.
Whatta you guys think of this setup? Any thoughts what the dyno #'s are going to be with a conservative tune? How will this exhaust effect the sound out the back?
Old Jun 14, 2004 | 11:48 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Default Re: OOPS! I did it again...... (dads01dream)
You done GOOD...........................but keep one eye open when you sleep at night
Old Jun 15, 2004 | 12:02 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Cool My guess is 510rwhp...
Old Jun 15, 2004 | 12:21 AM
dads01dream
Default Re: OOPS! I did it again...... (Z06GMAN)
Too true! You may have noticed the new/improved ($$ less) sig in my posts? I just couldn't leave a paper trail any longer. Which reminds me.... I need to update it yet again!
And I haven't even gotten the car back from the first round of mods started just a week ago.
Any more answers to my questions about power estimates/sound from the LT's and lastly correct pipe diameter selection? Thanks to all!
Old Jun 15, 2004 | 02:10 AM
QuickSilver2002's Avatar
QuickSilver2002
It should sound real good. I don't think it will be too loud. If you want loud, just take the cats off. I can literally scare people driving down the road when giving the throttle a good blip . Part throttle it is a kitten - open her up and people jump. Sound is one of those things you just get used to. No matter how loud it is, it seems tame after a few months. It will also change sound as carbon builds up in the new pipes.
A blower + a good set of pipes is the best sound you can have while cruising around town (IMHO). Turbos sound better at WOT, but you just can't beat the blower at part throttle.
Don't get too caught up with the dyno #s. The autos will always dyno quite a bit lower, but you make up for it on the street by keeping the boost up during shifts.
correct pipe diameter selection? Are you talking about the LTs. If so, that discussion is overrated. I would not worry about a few lbs of tq if you are making this much power, you will be fine with all those LTs.
Good luck.
[Modified by QuickSilver2002, 1:14 AM 6/15/2004]
Old Jun 15, 2004 | 08:44 AM
SleepieAce's Avatar
SleepieAce
From: Kentucky basketball is life the rest is just details
Default Re: OOPS! I did it again...... (QuickSilver2002)
Old Jun 15, 2004 | 09:46 PM
dads01dream
Thanks for putting things in perspective, Quick! I don't really care what the car dyno's out at..... Just so long as it's a CONSERVATIVE tune that will give me some terrific driving experiences.
Old Jun 15, 2004 | 11:51 PM
asmokegars's Avatar
asmokegars
St. Jude Donor '03-'06-'07-'08
Its a small step up to the F-1 blower, bigger injectors, a boost pump for the fuel, a little more rear-end. Lets see now I have Doug taking weight out here and there. Maybe next is the 225 heads, the fast intake vs the LS6,and even bigger throttle body than the BBK 80MM. I have the Kooks now and got rid of the TPIS. Came clean with the spouse. That feels good but makes it more of a challenge to do more below the radar.
Old Jun 16, 2004 | 05:26 AM
dads01dream
Default Re: OOPS! I did it again...... (asmokegars)
Great comment "Came clean with the spouse. That feels good but makes it more of a challenge to do more below the radar. " I just about the same as you do, a little more here & little more there when it comes to these darned car mods.
Old Jun 16, 2004 | 09:45 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Sounds like a good plan.
Old Jun 16, 2004 | 01:04 PM
FastCorvette5454's Avatar
FastCorvette5454
5th Gear
Default Re: OOPS! I did it again...... (runamuk)
sounds not cool at all
Old Jun 16, 2004 | 01:05 PM
FastCorvette5454
5th Gear
Default Re: OOPS! I did it again...... (FastCorvette5454)
hey i got a corvette rental the other day from my wreck, and i decided to go for a little speed. Except the thing isnt too cool. im all leaning back and its super flaming. corvettes are a bit overrated i must say. ill stick with a ford
Old Jun 16, 2004 | 01:13 PM
dads01dream
I think perhaps someone needs their diaper changed? Not a very good way to start out as a member here, pal!
Old Jun 16, 2004 | 01:26 PM
Hool97's Avatar
Hool97
What's the purpose of the previous posts, your opinion is, well *****.
Nice step -up you will be scary fast with the high stall. Traction will be a huge problem. But it will be a Blast.
Old Jun 16, 2004 | 02:24 PM
FastCorvette5454
5th Gear
im sorry maybe i dont know how the thing works y do u think i came to a site about corvettes
im not some intellectual
quit being a chicken licker and
Old Jun 16, 2004 | 08:17 PM
dads01dream
CHILDREN
To OOPS! I did it again......
