Supercharged 383: It's dyno time!
Old Jun 18, 2004 | 04:15 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Supercharged 383: It's dyno time!
I just talked to Mike @ Norris Motorsports and my car is on the dyno right now!!! Wish me luck!!! Assuming nothing breaks or is wrong with the car I should have some numbers posted up here no later than 7PM EST!
Old Jun 18, 2004 | 04:20 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: Supercharged 383: It's dyno time! (diynoob)
waiting on #s
Old Jun 18, 2004 | 04:49 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Supercharged 383: It's dyno time! (93Polo)
Old Jun 18, 2004 | 05:50 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Hey guys, I need some help. I just talked to Mike again and the car is having problems holding boost. It is getting up to 5 pounds and then dropping off after that. He thinks it might be belt slip. He mentioned his guys checked the BOV and no boost is leaking out of there. This is the A&A single intercooler kit.
Any ideas what might be going on? He mentioned belt tension is real good and this is an 8 rib kit -- so we're both at a loss as to why the belt could be slipping?
I guess on the plus side, it made about 500tq with only 5 pounds at about 4000RPM...
[Modified by diynoob, 5:23 PM 6/18/2004]
Old Jun 18, 2004 | 06:01 PM
QuickSilver2002's Avatar
QuickSilver2002
What size/type of pulley is on the blower. Any belt dust?
Old Jun 18, 2004 | 06:22 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Re: Supercharged 383: It's dyno time! (QuickSilver2002)
It's an ATI 3.85" 8 rib pulley. Mike didn't see any belt dust when I talked to him. One of his techs reported a high pitched whine but that could be unrelated.
They also mentioned that fuel pressure dropped off when boost dropped off which makes sense since it's a boost referenced regulator.
Old Jun 18, 2004 | 06:40 PM
Terry Burger's Avatar
Terry Burger
Does the AF/timing look ok?
Old Jun 18, 2004 | 07:00 PM
SideStep's Avatar
SideStep
SWEET!!!
Let us see the numbers!!!
Old Jun 18, 2004 | 07:27 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Re: Supercharged 383: It's dyno time! (Terry Burger)
Mike didn't mention anything abnormal about A/F or timing. Of course the tune gets really wacky up top because my fuel pressure regulator is boost referenced. So less boost = less fuel = dyno funkiness.
Old Jun 18, 2004 | 08:50 PM
Hool97's Avatar
Hool97
Check the throttle body blade is opening and staying open at WOT. IF it closing the amount of air flow will be limited and boost inside the intake will not go up (though it may creep up a little).
Old Jun 18, 2004 | 08:52 PM
Hool97's Avatar
Hool97
Also check for intake boot colapse prior to SC. Sometimes on F1s this can colapse from the suction but not usually on P1s or D1s.
Old Jun 18, 2004 | 08:54 PM
Hool97's Avatar
Hool97
Nice no. on 5lbs.
Old Jun 18, 2004 | 09:51 PM
QuickSilver2002
Default Re: Supercharged 383: It's dyno time! (Hool97)
humm.. it's hard to help much over the internet in these situations.
Here are a few ideas:
first, check for leaks in all the plumbing and intercooler.
If that shows nothing, focus on the belt. Try a larger pulley (if you can find one handy) it would be best if it was one of the reichard racing pulleys. I really don't like the way the ATI pulleys don't match up with the ribs on the belts. If a larger pulley shows more boost you know it is belt slip related.
Keep us posted on the progress.
Man, it seems like everyone is having trouble with new setups these days. I'm sure it will get resolved soon.
Old Jun 18, 2004 | 10:53 PM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
If there are no leaks in the system, it would seem that belt slippage is happening.
Good luck!
JB
Old Jun 18, 2004 | 11:14 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Re: Supercharged 383: It's dyno time! (jbsblownc5)
Thanks guys for your suggestions. I talked to Andy late today (gotta love that 3 hour EST to PST time difference, I called at 8:30PM EST and Andy was still at his shop since it was only 5:30PM PST). He talked to Mike and it sounds like it is indeed belt slip related. I have my fingers crossed that it's belt slip because if it is, there's a strong chance my tune will be finished tomorrow still. If it's not belt slip then it might be another week or so before I get the car.
Hool97: I too was encouraged by the ~500tq at 5psi number. Those were ballpark numbers, hopefully the final output is equally good. With the 3.85 pulley I am planning on 10-12psi of boost. So I am hoping for 600rwtq! Also, interesting thought on the throttle blade. I'll pass that along to Mike and see what he thinks.
[Modified by diynoob, 10:15 PM 6/18/2004]
Old Jun 20, 2004 | 02:53 PM
urslooow's Avatar
urslooow
any luck on your problem?
Old Jun 20, 2004 | 04:03 PM
Sportsdude's Avatar
Sportsdude
To Supercharged 383: It's dyno time!
Old Jun 20, 2004 | 09:33 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Re: Supercharged 383: It's dyno time! (urslooow)
No luck picking up the car this weekend. I'm a little disappointed and Mike Norris is too. Even though I'm not doing any of the work, both of us are a little burned out on getting this car done. There have been various contributing issues at work here but at this point it looks like it's just a belt slip problem which should be solved during this week.
I'll post back the moment I have a more meaningful dyno number. If the rest of the power and torque curves hold true to what we've already seen (~500tq @5psi) then this car should be a monster at 10-12psi when the belt's not slipping and the tune is 100% dialed in.
Old Jun 20, 2004 | 10:19 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Hang in there you know it will be worth it, But WAITING SUCKS Good Luck
Old Jun 21, 2004 | 07:39 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Goodluck, if anyone can figure it out I'm sure Mike will
