My i/c magnacharger project
Old 06-26-2004, 10:34 AM
c5_from_jc
c5_from_jc's Avatar
Default My i/c magnacharger project
Hi All,
I've been reading this board for a while, but this is my first actual post. I have a bone stock 2002 coupe I am putting the i/c Magnacharger on. I will let y'all know how it goes. Does anyone have any suggestions about additional bolt ons that work well with the Mag?
BTW, I am getting the MCM hood for my car. Don at yourcorvette.com gave me the best price in the country for the hood. Everything is ordered and on it's way!
Old 06-26-2004, 01:01 PM
XCELER8
XCELER8's Avatar
Default Re: My i/c magnacharger project (c5_from_jc)
Goodluck
Old 06-26-2004, 01:29 PM
runamuk
runamuk's Avatar
Cruise-In V Veteran
St. Jude Donor '04
don't forget the pics
Old 06-26-2004, 01:47 PM
mdhmi
mdhmi's Avatar
Congrats on the new blower. You should consider changing your plugs to NGK TR6's. I'm sure you'll love your new setup.
Mark
Old 06-26-2004, 02:33 PM
c5_from_jc
c5_from_jc's Avatar
Default Re: My i/c magnacharger project (mdhmi)
Yes, thanks for the reminder. I am also considering the 21st century blower cam.
Old 06-26-2004, 02:46 PM
Sack Rat TT
Sack Rat TT's Avatar
Good tip concerning using NGK TR-6 plugs. Also a good time to change out the thermostat and reprogram the fans when you do the tune. Good Luck
Old 06-26-2004, 04:07 PM
IM QUIKR
IM QUIKR's Avatar
Everything else is academic without a proper tune. Take pics along the way to chronicle the install. We'd like to see how this comes together.
[Modified by drcoffee, 3:07 PM 6/26/2004]
Old 06-26-2004, 05:00 PM
c5_from_jc
c5_from_jc's Avatar
Default Re: My i/c magnacharger project (drcoffee)
I am having this thing professionally insalled and tuned. I don't trust myself with this kind of thing.
Old 06-26-2004, 09:54 PM
SteveL2
SteveL2's Avatar
Congrats on the project. I'll throw in my $0.02.
I have the Mag & that cam in my car, but my Mag is not intercooled. The cam made a big difference about 5,500 rpms or so, and indeed very much necessitated new valve springs. I'm wondering if the intercooled Mag alone, because it can provide more efficient psi, will even without the cam perform better at higher rpms, thereby also benefitting from better springs.
Just a thought, as at least a handful of folks have found the stock springs to not handle the upper rpms very well.
Old 06-26-2004, 10:21 PM
c5_from_jc
c5_from_jc's Avatar
Default Re: My i/c magnacharger project (SteveL2)
Great point. At a minimum, I probably should upgrade the springs. I know someone else who is doing that.
Old 06-26-2004, 10:53 PM
AVB
AVB's Avatar
pcv mod / catch can if you haven't already..
Old 06-27-2004, 11:37 AM
Sack Rat TT
I have the Mag & better at higher rpms, thereby also benefitting from better springs.
New upgraded springs come with the cam if you decide to go with a cam change or you could change springs without a cam change. The hardest part of the install is pining the crankshaft. Good Luck
[Modified by Sack Rat TT, 10:41 AM 6/27/2004]
Old 06-27-2004, 11:43 AM
mdhmi
mdhmi's Avatar
Default Re: My i/c magnacharger project (magdc5)
Very good point. I'm having a catch can installed next week when my blower goes in. (Also doing Racetronix, 160 thermo, Comp 918 valve springs, and NGK plugs).
Cheers,
Mark
Old 06-28-2004, 11:53 AM
vettewreck
vettewreck's Avatar
I put this cam in my Magnachared vette and gained 60rwhp and 30rwtq GET IT AND THE MATCHING SPRINGS!!!!
To My i/c magnacharger project
Quick Reply: My i/c magnacharger project
