Supercharger Project
Old Jun 27, 2004 | 10:05 AM
waymirec's Avatar
waymirec
Default Supercharger Project
Ok. I'm getting ready to do a major overhaul on my '99 FRC and just wanted to get some opinions from everyone:
Xtreme 346 (5.7L) Forged Bottom End with Heads/Cam
- Eagle forged 3.622 crank
- Eagle H-Beam 6.125 forged rods
- JE custom low compression pistons / rings
- Balance rotating assembly
- Katech/GM Ported Oil Pump
- Katech/GM Timing Chain / Gears
- Custom ground Comp Cam
- Comp Cams 850 Lifters
- Comp Cams Hardened Pushrods
- LPE Stage2 Ported LS1 Heads 2.02/1.57
- Cometic Head Gaskets / Front & Rear Cover / Oil Pan / Front & Rear Seals / Valley Cover
- ARP Head Studs
- NGK TR6 Plugs
- Mobil1 10W30 with UPF44 Oil Filter
- 160 Hypertech T-Stat
- Ported Throttle Body (exchanged)
- 01-up LS1/LS6 intake manifold
A&A Corvette D1SC Supercharger kit (8-Rib Accessory Belt drive)
Installation includes, fuel pump, boosta pump, injectors, and tuning
- Gauge Pod A-Pillar (2 Cobalt Gauges fuel press / boost)
- A&A Radiator
- GHL Magnum 4-Tip
- Exedy Twin Disk Clutch
- DTE Strut kit (tranny/diff)
This will all be purchased through and installed by Xtreme Motorsports in Tempe, AZ and will all be installed at the same time. Fire away with opinions/criticisms.
[Modified by waymirec, 8:01 AM 6/28/2004]
Old Jun 27, 2004 | 10:28 AM
mdhmi's Avatar
mdhmi
Default Re: Supercharger Project (waymirec)
The D1SC is going to be *much* more fun than a H/C package IMHO. What are your goals for the car? How/where do you intend to drive it?
Mark
Old Jun 27, 2004 | 10:36 AM
waymirec's Avatar
waymirec
Oh no. I'm having BOTH packages put in. First the forged bottom with the H/C package and all the goodies. THEN the A&A D1SC. As for the vehicle itself.. eventually it's going to basically be a SHOW&GO car.
Old Jun 27, 2004 | 11:46 AM
mdhmi's Avatar
mdhmi
Then your definitely going to love it.
Cheers,
Mark
Old Jun 30, 2004 | 01:47 PM
waymirec's Avatar
waymirec
Well... the parts have been ordered and my car will soon be in the very capable hands of Bill @ Xtreme Motorsports. Bill has been nothing short of awesome so far, even going the "extra mile" and offering to take pictures of the whole process so that I can later post pictures. Cant wait to see their handiwork in action.
Old Jun 30, 2004 | 05:51 PM
FreddyG's Avatar
FreddyG
It has the makings of a real BEAST, but if it were mine, I'd change the ported LS1 heads to ported 6 liters. This would lower the compression more, and give you the benefit of LS6 style ports. you could really crank the boost then to whatever the ATI/A&A pulleys could handle. Good Luck and Drive Safely!
Old Jul 4, 2004 | 04:30 PM
dads01dream's Avatar
dads01dream
Default Re: Supercharger Project (LuvmyC5)
BEAST may even be an understatement for this car!! If I were doing a set of heads/cam.... I'd be shopping AFR. Hopefully, when I am in the market the 225's will be ready. For now it may be worth looking into a set of 205's??
Can't wait to hear how things workout for ya.
Old Oct 7, 2004 | 03:20 AM
waymirec's Avatar
waymirec
Ok. So this portion of the project is pretty much complete. The exhaust still needs to be put on and theres a minor belt-slip issue at redline thats going to be addressed through a bracket modification. As it stands it dyno'd at 608rwhp and 518rwtq. We'll see what the new numbers are after the slip issue is resolved and the GHL Magnum is installed.
Bill over at Xtreme was kind enough to take pictures throughout the process. They can be seen at http://www.waymire.net/photogallery/...album=9&page=1
Old Oct 7, 2004 | 08:43 AM
jonjon's Avatar
jonjon
That thing's a monster. Congrats
Old Oct 7, 2004 | 10:00 AM
mdhmi's Avatar
mdhmi
Stage II LS1 heads will flow at least as well as standard AFR 205's. Considering you will have a forged bottom-end and a blower cam running a D1SC with a small pulley I wouldn't bother spending $2,500 - $3,000 on heads. You'll have 600 rwhp with your setup without even leaning on it..
Mark
Old Oct 7, 2004 | 10:46 AM
XCELER8's Avatar
XCELER8
Mark
I fully agree with Mark
Get a nice set of 6.0 heads ported and you will see even larger MONSTER numbers.
Jon
Old Oct 15, 2004 | 11:01 PM
waymirec's Avatar
waymirec
Got the final dyno results from Xtreme. This was dyno'd with the stock exhaust as we havent gotten around to putting on the GHL Magnum yet but I'll let Bill's work speak for itself.
So Bill.. whats the next step to get closer to 700rwhp??
Old Oct 15, 2004 | 11:26 PM
Bill Reid's Avatar
Bill Reid
more power?... you'll need more fuel, o-ring heads, main studs/girdle, and an F1 head unit If you find your new found power boring come back and see me... I'll scare up some more for ya Thanks for your business Chris... we really appreciate it. I just can't wait to see the project completed with the all new interior, exterior paint, and a nice brake/wheel/tire package to tuck under that freshly tubbed rear end
Old Oct 16, 2004 | 09:32 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Very nice, whos headers are those?
Old Oct 16, 2004 | 09:53 AM
XCELER8's Avatar
XCELER8
great numbers...AHH..making me want mine now.
Jon
Old Oct 16, 2004 | 12:36 PM
BlackMagicC5's Avatar
BlackMagicC5
Wow!!! Those pictures are awesome. All 47 of them. After looking at every picture, I feel like I was there watching the entire install. Looks like its going to be fun.
Old Oct 19, 2004 | 03:01 AM
waymirec's Avatar
waymirec
For those that are like me and enjoy watching video clips of Vette's im posting a link to a short 4min video my good friend Jonathan put together for me. He's taking care of my car while i'm away and is handling all the leg work on getting the modifications done to it. I'm sure all the work he's put in is a fair trade off for having the opportunity to make a video like this. The zip file is roughly 45megs. You can download it here. You may need the latest DivX 5 driver to view the video.
Good job Jonathan
p.s.
please ignore the condition of the paint as well as the rear end (yes i know its cracked) as that will be remedied as soon as the interior is finished.
Old Oct 24, 2004 | 06:04 PM
JaminJ's Avatar
JaminJ
They charged you $28,500??? with what looks like a used procharger.
I don't know......are you doing your friend a favor...Will he be happy when back from his tour in the Mideast.
Looks like Dave's handy work.
Old Oct 24, 2004 | 06:38 PM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
i don't know about the eagle parts.... i heard some bad stuff over on LS1tech about the rods having problems. do a search over there before you get eagle stuff
To Supercharger Project
