Window Switch....
Old Jul 1, 2004 | 07:35 PM
Fastbasser's Avatar
Fastbasser
Default Window Switch....
Why do you need one with an A4?
Old Jul 1, 2004 | 08:17 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Window Switch.... (Fastbasser)
if you are running the stock converter, then its possible to puddle the intake even with an A4
Old Jul 1, 2004 | 08:35 PM
Fastbasser's Avatar
Fastbasser
Default Re: Window Switch.... (ICULUKN-C5)
Thanks for the reply.. I have mine set to open at about 7/8s throttle. In most cases, Im well above 3000 when it engages. Can I "assume" the few times a hit wot from a dead stop, not all the fuel/nitrous is goi down the throttle body?
I have my nozzles directly in front of the t-body.
Thanks,
Old Jul 2, 2004 | 12:49 AM
mikey94_95's Avatar
mikey94_95
Fastbasser,
If you are looking for one, feel free to write me at mike@bmnracetech.com
Old Jul 2, 2004 | 12:58 AM
ICULUKN-C5's Avatar
ICULUKN-C5
The reason for the window switch is to ensure proper vacuum in the intake to pull the nitrous/fuel mix into the cylinder. Chemically nitrous and fuel do not want to mix and spend all their time repelling each other. If it takes too long to get the mix into the cylinder they will separate. Fuel will stick to the top of the intake, and ignite from the valve heat, while the nitrous will get pulled into the cylinder and cause a lean condition.
To Window Switch....
