he is checking the backpressure in his exhaust system. backpressure kills hp and that sounds like a lot of backpressure, blu. I am probably in the same boat as you are. I've been thinking about building a custom 3" exhaust with Borla xr's, 2 chamber flowmasters or warlock mufflers. with that kind of backpressure, I would think the change would be good for at least 20hp.
2x boost is the most you want to see on a turbo manifold, but that is a totally different deal.
I'm guessing that 15psi is way too high, but I have nothing to back it up.
Me neither. What is too much pressure? Does a 'free-flow' exhaust have no backpressure? And if there's 15psi in the exhaust pipe, what does that mean for the cylinder(s)?
Part of why I took a beer break is the car threw codes at me and lost power. But if I think about it, I didn't plug both 1/4" lines, just hooked one up to the boost gauge. I cleared the codes but maybe it's an O2 sensor unhappy with sniffing clean air.
This is a pretty free-flowing exhaust setup I put together. Of course I've still got the stock cats, but it's after there that it's all wide open / straight through design. Check out the video / sound clip to see how quiet it still is.
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
I don't have the answer as to how much is typical, however you now have your baseline, now get a set of LT's w/high flow cats and a good set of mufflers, check again and you (we) will have the answer!
I like that you look into these things with gusto-I wish I had your spunk!
Good luck,
Roy
Ramcharger, looks pretty cool! I think my problem is cats forward. A previous tuner couldn't get it right and it ran pig rich for a weeks' worth of driving. I was worried pig rich was bad for the cats. I don't think it looks ricer, the tips aren't big enough.
Supervette, it's a curse that I dig into problems! I waste so much time trying to outsmart myself that I end up below the average curve. If I only were a normal consumer and ignorant of the detail of how things worked, life would be much easier (on me).
That being said, I wonder if there's any backpressure with cut-outs? (Hmm, he says, and wanders off with the cord of a die-grinder trailing behind him).
Cats prefer rich, actually. It keeps them cooler. When the cats begin to overheat in some cars, they richen up the mixture if they can to keep the cats at normal temperature. I have no idea how more hydrocarbons helps the catalytic converters stay cool but that's the story.
Keep in mind that it's the whole setup that determines what your backpressure is. Did your pressure gage peak at 15psi and drop or did it stay there? It'd be interesting to see on the street (or dyno) what it does after you get your exaust flowing through the pipes. Of course it'll be very different under load than simply taking the engine to redline in your driveway or on jackstands.
Backpressure goes up and down with rpm if under load. If it's partial throttle pressure varies from 2-5psi.
Yesterday passenger side pressure went to 15psi@5,000rpm, today drivers' side went to 10psi@5,000rpm. I think they're probably closer but today I had issues with the A4.
If you can think of a quick and easy way to hook up a fitting to an 02 bung I'll run a test on mine. I really don't want to poke another hole in my collector. I guess you also have to use some type of metal tubing for the first foot or two. ( I would imagine rubber or plastic melting pretty fast)
The bungs are metric thread (18mm?). There are some parts store oil plugs that would fit, and the plug could be drilled and tapped for 1/8-npt pipe thread. You mentioned collectors, do you have headers and cats? Edit: I checked your profile, LG Pro LT headers
I went to ACE hardware and got two setups of; 1) 1/8male-1/4 flare adapter, 2) flare nut with ring, 3) 1/8 plug (for after testing) and 4) 10' box of 1/4" copper tubing. From the auto parts store I bought some 1/8" and 5/16" rubber caps to cap off the open ports.
I drilled 3/8" holes just before cats, and tapped those. Screwed the adapter in, ran the tubing down from the master cylinder, slid the nut and ring over the end of the tube, and attached that.
The boost sensor is connected the top end of the tubing with about a foot of rubber hose. I could've just used one tube and moved it underneath, but it was easier to move the hose between tubes up top.
I had an 02 bung cap at one time, but I cannot find it now. I'll rig it up if I can find something cheap. I remember them charging me over $10 for the cap last time.
$2.50 for a grade-8 18mm drain plug at the auto parts store. You'll need a cobalt bit to drill it before you tap it.
